Hello everyone.
I want to define a custom board so I can select it when I want to build a code.
I'm looking for a documentation to do that from espressif but I haven't find yet.
Thanks.
How to define a custom board
Re: How to define a custom board
ESP-IDF does not work with board defines. Are you asking about Arduino?
ashegheparyshun
I'm trying to build an application for the Matter protocol.
my dev kit is esp32s3 devkit (which has a ws2812 rgb led) and I'm using Ubuntu.
For my first step I tried the light example from esp-matter sdk and it worked for me.
Next I tried to modify the example to expand the number of rgb leds to 2 but I failed.
I tried to change the number of rgb leds in the sdkconfig but it returns the number of leds to 1.
I changed the maximum number of leds in all the related file in the example but I failed too.
So, I'm trying to find a way to increase the number of leds. I thought if I could define a new board, I could increase the number of leds too.
What are you expecting to happen? The example itself only controls one LED source (indirectly, via a driver that also seems to only support one LED), so you'd need to do more than set the LED count to 2 in order to control multiple LEDs via Thread.
Users browsing this forum: ChatGPT-User and 7 guests
