ESP32-S2 : ADC unit can not be controlled by the ULP RISCV (ADC_ULP_MODE_RISCV)
Dorian
Postby Dorian » Fri May 09, 2025 8:58 am
Hi all,
I encountered an issue on the ESP32-S2-MINI2 (ESP-IDF Release v5.4.1) that the ULP is not able to read any ADC value unless I configure it as ADC_ULP_MODE_DISABLE.
ADC unit (GPIO9-ADC1_CHN8)
ULP RISCV - ADC_ULP_MODE_DISABLE - returns new and fresh values
ULP RISCV - ADC_ULP_MODE_RISCV - returns always 8191
The main issue is that the ADC_ULP_MODE_DISABLE configuration does not work in light sleep. It will always return the last ADC value, then it is stale. This is already known and highlighted in several tickets.
I have tried all ESP IDF ULP RISCV examples, all workarounds from different tickets regarding compiler options, power modes/domains, etc., and also the ADC Legacy code.
The ADC configuration comes down to this function:
__attribute__((always_inline))
static inline void adc_ll_set_controller(adc_unit_t adc_n, adc_ll_controller_t ctrl)
    if (adc_n == ADC_UNIT_1) {
        switch (ctrl) {
        case ADC_LL_CTRL_RTC:
            SENS.sar_meas1_mux.sar1_dig_force       = 0;    // 1: Select digital control;       0: Select RTC control.
            SENS.sar_meas1_ctrl2.meas1_start_force  = 1;    // 1: SW control RTC ADC start;     0: ULP control RTC ADC start.
            SENS.sar_meas1_ctrl2.sar1_en_pad_force  = 1;    // 1: SW control RTC ADC bit map;   0: ULP control RTC ADC bit map;
        case ADC_LL_CTRL_ULP:
            SENS.sar_meas1_ctrl2.meas1_start_force  = 0;    // 1: SW control RTC ADC start;     0: ULP control RTC ADC start.
            SENS.sar_meas1_ctrl2.sar1_en_pad_force  = 0;    // 1: SW control RTC ADC bit map;   0: ULP control RTC ADC bit map;
        case ADC_LL_CTRL_DIG:
            SENS.sar_meas1_mux.sar1_dig_force       = 1;    // 1: Select digital control;       0: Select RTC control.
        default:
    } else { // adc_n == ADC_UNIT_2
This shows that the ULP is unable to control the RTC ADC, or there is a missing configuration that needs to be added.
Can someone confirm that the ULP RISCV can read new and fresh ADC data when the ulp_adc_init is used? What could cause this issue?
Bug ticket created https://github.com/espressif/esp-idf/issues/15927
Thank you
ahsrabrifat
Re: ESP32-S2 : ADC unit can not be controlled by the ULP RISCV (ADC_ULP_MODE_RISCV)
Postby ahsrabrifat » Fri May 09, 2025 10:18 am
The ULP RISC-V may not correctly enable ADC clocks or power domains needed for RTC ADC operation.
Dorian
Postby Dorian » Sun May 11, 2025 6:30 pm
I also have to note that this issue is happening in Active mode (no sleep) as well, so the clocks and power domains are enabled.
I have also modified only the sub-function that selects who is controlling the ADC unit (RTC or ULP), to keep the same function call tree:
- ADC with RTC as control -> ULP can read ADC
- ADC with ULP as control -> ULP can not read ADC
So I think that ULP has no access directly to the ADC, or the latest esp idf release broke something, but that would be reported by many others already.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 1 guest
