debug求助:如何配置raw_opus_decoder的参数,以与最简python server通信,播放音频
Posted: Sat May 10, 2025 6:29 am
by esp3223pse
板子:esp32s3
idf: 5.3.2
adf:2.4
代码逻辑:在server端,加载wav文件,读取后用opuslib_next.Encoder编码为raw opus帧,在esp32用raw_opus_decoder进行解码播放
问题:在server端,不管开不开启大端序长度前缀,在esp32不管怎么设置参数,都没有播放
已经确认的:
1. 设备正常:用pipeline_http_select_decoder例程可以正常播放https://github.com/espressif/esp-adf/bl ... ADME_CN.md
2. esp32接收到了opus帧
万分感谢
opus_play_server.py:
import os
import random
import wave
import numpy as np
import opuslib_next
import time
import struct
import asyncio
import websockets
import logging
import json
from threading import Thread
# 配置日志
logging.basicConfig(level=logging.INFO, format='%(asctime)s - %(name)s - %(levelname)s - %(message)s')
logger = logging.getLogger("opus_server")
# 配置参数
WAV_DIR = 'recordings'
HOST = '0.0.0.0'  # 监听所有网络接口
PORT = 8000
SAMPLE_RATE = 16000
CHANNELS = 1
FRAME_SIZE = 960  # 60ms @ 16kHz, 样本数
APPLICATION = opuslib_next.APPLICATION_VOIP
wav_files = [f for f in os.listdir(WAV_DIR) if f.endswith('16000hz.wav')]
def read_wav_file(file_path):
    """读取WAV文件并返回PCM数据"""
    with wave.open(file_path, 'rb') as wav_file:
        # 检查采样率和通道数
        if wav_file.getframerate() != SAMPLE_RATE:
            raise ValueError(f"WAV文件采样率必须为{SAMPLE_RATE}Hz")
        if wav_file.getnchannels() != CHANNELS:
            raise ValueError(f"WAV文件必须为{CHANNELS}通道")
        # 读取所有音频数据
        pcm_data = wav_file.readframes(wav_file.getnframes())
    return pcm_data
def encode_opus(pcm_data):
    """将PCM数据编码为Opus格式"""
    # 创建Opus编码器
    encoder = opuslib_next.Encoder(SAMPLE_RATE, CHANNELS, APPLICATION)
    # 将字节数据转换为16位整数数组
    samples = np.frombuffer(pcm_data, dtype=np.int16)
    # 按帧大小分割数据
    frames = [samples[i:i+FRAME_SIZE] for i in range(0, len(samples), FRAME_SIZE)]
    # 编码每一帧
    encoded_frames = []
    for frame in frames:
        # 如果最后一帧不足FRAME_SIZE,则用0填充
        if len(frame) < FRAME_SIZE:
            frame = np.pad(frame, (0, FRAME_SIZE - len(frame)), 'constant')
        # 编码
        encoded = encoder.encode(frame.tobytes(), FRAME_SIZE)
        frame_length = len(encoded)
        # 添加长度前缀
        # length_prefix = struct.pack('>H', frame_length)  # 2字节大端序长度前缀
        # length_prefix = frame_length.to_bytes(2, byteorder='big')
        # encoded_frames.append(length_prefix + encoded)
    return encoded_frames
async def handle_client(websocket):
    """处理WebSocket客户端连接"""
    client_ip = websocket.remote_address[0]
    logger.info(f"客户端已连接: {client_ip}")
    try:
        # 发送初始化消息
        await websocket.send(json.dumps({
            "type": "hello",
            "status": "ok",
            "sample_rate": SAMPLE_RATE,
            "channels": CHANNELS
        while True:
            # 获取WAV文件列表
            if not wav_files:
                logger.warning("没有找到WAV文件")
                    "type": "error",
                    "message": "没有可用的音频文件"
                await asyncio.sleep(5)
                continue
            # 随机选择一个WAV文件
            wav_file = random.choice(wav_files)
            wav_path = os.path.join(WAV_DIR, wav_file)
            logger.info(f"正在发送文件: {wav_file}")
            # 发送文件开始消息
                "type": "file_start",
                "filename": wav_file
            try:
                # 读取并编码WAV文件
                pcm_data = read_wav_file(wav_path)
                encoded_frames = encode_opus(pcm_data)
                # 发送编码后的数据
                for frame in encoded_frames:
                    logger.info(len(frame))
                    await websocket.send(frame)
                    await asyncio.sleep(0.02)  # 模拟实时流,每20ms发送一帧
                logger.info(f"文件 {wav_file} 发送完成")
                # 发送文件结束消息
                    "type": "file_end",
                await asyncio.sleep(1)  # 文件之间的间隔
            except Exception as e:
                logger.error(f"处理文件 {wav_file} 时出错: {e}")
                    "type": "error",
                    "message": f"处理文件出错: {str(e)}"
            break
    except websockets.exceptions.ConnectionClosed as e:
        logger.info(f"客户端断开连接: {client_ip}, 代码: {e.code}, 原因: {e.reason}")
        logger.error(f"处理客户端 {client_ip} 时出错: {e}", exc_info=True)
async def start_server():
    """启动WebSocket服务器"""
    server = await websockets.serve(
        handle_client,
        HOST,
        PORT
    logger.info(f"Opus WebSocket服务器启动在 ws://{HOST}:{PORT}")
    return server
def main():
    """主函数"""
    # 检查WAV目录是否存在
    if not os.path.exists(WAV_DIR):
        os.makedirs(WAV_DIR, exist_ok=True)
        logger.info(f"创建WAV目录: {WAV_DIR}")
    # 启动异步事件循环
    loop = asyncio.get_event_loop()
    server = loop.run_until_complete(start_server())
    try:
        loop.run_forever()
    except KeyboardInterrupt:
        logger.info("服务器关闭")
    finally:
        server.close()
        loop.run_until_complete(server.wait_closed())
        loop.close()
if __name__ == "__main__":
    main()
esp32:
/* 使用多种解码器解码 WebSocket 服务器的 Opus 音频 */
#include <string.h>
#include "freertos/task.h"
#include "freertos/event_groups.h"
#include "esp_log.h"
#include "esp_wifi.h"
#include "nvs_flash.h"
#include "sdkconfig.h"
#include "audio_element.h"
#include "audio_pipeline.h"
#include "audio_event_iface.h"
#include "audio_common.h"
#include "esp_peripherals.h"
#include "periph_wifi.h"
#include "board.h"
#include "i2s_stream.h"
#include "raw_stream.h"
#include "filter_resample.h"
#include "ringbuf.h"
// 选择解码器类型
// 可选值:
// 1 - RAW_OPUS_DECODER (带帧长度前缀)
// 2 - RAW_OPUS_DECODER (不带帧长度前缀)
// 3 - OPUS_DECODER
// 4 - ESP_OPUS_DECODER
#define DECODER_TYPE 1
#if (DECODER_TYPE == 1)
#include "raw_opus_decoder.h"
static const char *TAG = "RAW_OPUS_WITH_PREFIX";
#elif (DECODER_TYPE == 2)
static const char *TAG = "RAW_OPUS_NO_PREFIX";
#elif (DECODER_TYPE == 3)
#include "opus_decoder.h"
static const char *TAG = "OPUS_DECODER";
#else
#error "请选择有效的解码器类型"
#endif
#include "esp_websocket_client.h"
#define WEBSOCKET_URI "ws://192.168.31.132:8000" // 修改为您的服务器地址
#define BUFFER_SIZE 1024
static audio_pipeline_handle_t pipeline;
static audio_element_handle_t raw_write;
static audio_element_handle_t opus_decoder;
static audio_element_handle_t i2s_writer;
static esp_websocket_client_handle_t client;
ringbuf_handle_t raw_in_rb;
ringbuf_handle_t opus_in_rb;
static EventGroupHandle_t s_wifi_event_group = NULL;
// 定义事件组位
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT      BIT1
// 音频配置
#define SAMPLE_RATE     16000
#define CHANNELS        1
// WebSocket事件处理函数
static void websocket_event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data)
    esp_websocket_event_data_t *data = (esp_websocket_event_data_t *)event_data;
    switch (event_id) {
        case WEBSOCKET_EVENT_CONNECTED:
            ESP_LOGI(TAG, "WEBSOCKET_EVENT_CONNECTED");
            break;
        case WEBSOCKET_EVENT_DISCONNECTED:
            ESP_LOGI(TAG, "WEBSOCKET_EVENT_DISCONNECTED");
            break;
        case WEBSOCKET_EVENT_DATA:
            // 区分文本数据和二进制数据
            if (data->op_code == 2) {  // 二进制数据的操作码为 2
                ESP_LOGI(TAG, "接收到二进制数据, len=%d", data->data_len);
                // 打印前8个字节用于分析数据格式
                if (data->data_len >= 8) {
                    ESP_LOGI(TAG, "前8个字节: 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x",
                        data->data_ptr[0], data->data_ptr[1], data->data_ptr[2], data->data_ptr[3],
                        data->data_ptr[4], data->data_ptr[5], data->data_ptr[6], data->data_ptr[7]);
                // 将二进制数据写入Opus解码器
                if (data->data_len > 0) {
                    int bytes_written = raw_stream_write(raw_write, (char *)data->data_ptr, data->data_len);
                    ESP_LOGI(TAG, "写入 raw_stream %d 字节", bytes_written);
                    // 检查是否成功写入
                    if (bytes_written < data->data_len) {
                        ESP_LOGE(TAG, "写入 raw_stream 时发生错误,可能是缓冲区已满");
            } else {
                // 文本数据
                ESP_LOGI(TAG, "接收到文本数据, len=%d, 内容: %.*s",
                         data->data_len, data->data_len, (char *)data->data_ptr);
            break;
        case WEBSOCKET_EVENT_ERROR:
            ESP_LOGI(TAG, "WEBSOCKET_EVENT_ERROR");
            break;
// WiFi事件处理
static void wifi_event_handler(void *arg, esp_event_base_t event_base, int32_t event_id, void *event_data)
    if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
        esp_wifi_connect();
    } else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
        ESP_LOGI(TAG, "WiFi断开连接,尝试重连...");
        esp_wifi_connect();
        xEventGroupClearBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
        xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
    } else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
        ip_event_got_ip_t *event = (ip_event_got_ip_t *)event_data;
        ESP_LOGI(TAG, "获取到IP地址:" IPSTR, IP2STR(&event->ip_info.ip));
        xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
// 初始化WiFi
static void init_wifi(void)
    s_wifi_event_group = xEventGroupCreate();
    ESP_ERROR_CHECK(esp_netif_init());
    ESP_ERROR_CHECK(esp_event_loop_create_default());
    esp_netif_create_default_wifi_sta();
    wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
    ESP_ERROR_CHECK(esp_wifi_init(&cfg));
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL));
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &wifi_event_handler, NULL));
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = CONFIG_WIFI_SSID,
            .password = CONFIG_WIFI_PASSWORD,
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config));
    ESP_ERROR_CHECK(esp_wifi_start());
    ESP_LOGI(TAG, "WiFi初始化完成,等待连接...");
    // 等待WiFi连接
    EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
                                          WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
                                          pdFALSE,
                                          pdFALSE,
                                          portMAX_DELAY);
    if (bits & WIFI_CONNECTED_BIT) {
        ESP_LOGI(TAG, "已连接到WiFi");
    } else if (bits & WIFI_FAIL_BIT) {
        ESP_LOGE(TAG, "WiFi连接失败");
    } else {
        ESP_LOGE(TAG, "意外错误");
void app_main(void)
    esp_log_level_set("*", ESP_LOG_INFO);
    esp_log_level_set(TAG, ESP_LOG_DEBUG);
    ESP_LOGI(TAG, "[ 1 ] 初始化 NVS");
    esp_err_t err = nvs_flash_init();
    if (err == ESP_ERR_NVS_NO_FREE_PAGES) {
        ESP_ERROR_CHECK(nvs_flash_erase());
    ESP_ERROR_CHECK(err);
    ESP_LOGI(TAG, "[ 2 ] 初始化外设");
    // esp_periph_config_t periph_cfg = DEFAULT_ESP_PERIPH_SET_CONFIG();
    // esp_periph_set_handle_t set = esp_periph_set_init(&periph_cfg);
    ESP_LOGI(TAG, "[ 3 ] 初始化 Wi-Fi");
    init_wifi();
    ESP_LOGI(TAG, "[ 4 ] 创建音频管道");
    audio_pipeline_cfg_t pipeline_cfg = DEFAULT_AUDIO_PIPELINE_CONFIG();
    pipeline = audio_pipeline_init(&pipeline_cfg);
    mem_assert(pipeline);
    // 创建 raw_stream 作为数据输入点
    raw_stream_cfg_t raw_cfg = RAW_STREAM_CFG_DEFAULT();
    raw_cfg.type = AUDIO_STREAM_WRITER;
    raw_write = raw_stream_init(&raw_cfg);
    ESP_LOGI(TAG, "[ 5 ] 创建解码器");
    // RAW_OPUS_DECODER 带帧长度前缀
    raw_opus_dec_cfg_t opus_cfg = RAW_OPUS_DEC_CONFIG_DEFAULT();
    opus_cfg.sample_rate = SAMPLE_RATE;
    opus_cfg.channels = CHANNELS;
    opus_cfg.dec_frame_size = 960;  // 60ms @ 16kHz = 960 samples
    opus_cfg.enable_frame_length_prefix = true; // 启用帧长度前缀
    opus_decoder = raw_opus_decoder_init(&opus_cfg);
    ESP_LOGI(TAG, "使用 RAW_OPUS_DECODER (带帧长度前缀)");
    // RAW_OPUS_DECODER 不带帧长度前缀
    opus_cfg.enable_frame_length_prefix = false; // 禁用帧长度前缀
    opus_cfg.self_delimited = true; // 尝试使用自分隔模式
    ESP_LOGI(TAG, "使用 RAW_OPUS_DECODER (不带帧长度前缀)");
    // 标准 OPUS_DECODER
    opus_decoder_cfg_t opus_cfg = DEFAULT_OPUS_DECODER_CONFIG();
    opus_decoder = decoder_opus_init(&opus_cfg);
    ESP_LOGI(TAG, "使用标准 OPUS_DECODER");
#endif
    ESP_LOGI(TAG, "[ 6 ] 创建 I2S 流");
    i2s_stream_cfg_t i2s_cfg = I2S_STREAM_CFG_DEFAULT();
    i2s_cfg.type = AUDIO_STREAM_WRITER;
    // 增加 DMA 缓冲区配置
    i2s_cfg.chan_cfg.dma_desc_num = 8;  // 增加 DMA 缓冲区数量
    i2s_cfg.chan_cfg.dma_frame_num = 1024;  // 增加 DMA 缓冲区长度
    // 设置采样率、位深度和通道
    i2s_cfg.std_cfg.clk_cfg.sample_rate_hz = SAMPLE_RATE;
    i2s_cfg.std_cfg.slot_cfg.data_bit_width = I2S_DATA_BIT_WIDTH_16BIT;
    i2s_cfg.std_cfg.slot_cfg.slot_mode = I2S_SLOT_MODE_MONO;
    i2s_cfg.out_rb_size = 16 * 1024;
    i2s_writer = i2s_stream_init(&i2s_cfg);
    ESP_LOGI(TAG, "[ 7 ] 注册所有元素到音频管道");
    audio_pipeline_register(pipeline, raw_write, "raw");
    audio_pipeline_register(pipeline, opus_decoder, "opus");
    audio_pipeline_register(pipeline, i2s_writer, "i2s");
    ESP_LOGI(TAG, "[ 8 ] 链接元素: [raw] --> [opus] --> [i2s]");
    const char *link_tag[3] = {"raw", "opus", "i2s"};
    audio_pipeline_link(pipeline, &link_tag[0], 3);
    ESP_LOGI(TAG, "[ 9 ] 设置事件监听器");
    audio_event_iface_cfg_t evt_cfg = AUDIO_EVENT_IFACE_DEFAULT_CFG();
    evt_cfg.queue_set_size = 20;
    audio_event_iface_handle_t evt = audio_event_iface_init(&evt_cfg);
    audio_pipeline_set_listener(pipeline, evt);
    ESP_LOGI(TAG, "[ 10 ] 启动音频管道");
    audio_pipeline_run(pipeline);
    ESP_LOGI(TAG, "[ 11 ] 初始化WebSocket客户端");
    esp_websocket_client_config_t websocket_cfg = {
        .uri = WEBSOCKET_URI,
    client = esp_websocket_client_init(&websocket_cfg);
    esp_websocket_register_events(client, WEBSOCKET_EVENT_ANY, websocket_event_handler, NULL);
    ESP_LOGI(TAG, "[ 12 ] 启动WebSocket客户端");
    esp_websocket_client_start(client);
    ESP_LOGI(TAG, "[ 13 ] 监听事件");
    while (1) {
        audio_event_iface_msg_t msg;
        esp_err_t ret = audio_event_iface_listen(evt, &msg, 100 / portTICK_PERIOD_MS);
        if (ret != ESP_OK) {
            ESP_LOGE(TAG, "[ * ] 事件接口错误: %d", ret);
            // 增加短暂延迟,避免CPU占用过高
            vTaskDelay(pdMS_TO_TICKS(10));
            continue;
        if (msg.source_type == AUDIO_ELEMENT_TYPE_ELEMENT && msg.source == (void *)opus_decoder
            && msg.cmd == AEL_MSG_CMD_REPORT_MUSIC_INFO) {
            audio_element_info_t music_info = {0};
            audio_element_getinfo(opus_decoder, &music_info);
            ESP_LOGI(TAG, "[ * ] 接收到音频信息,采样率: %d, 通道数: %d",
                     music_info.sample_rates, music_info.channels);
            i2s_stream_set_clk(i2s_writer, music_info.sample_rates, music_info.bits, music_info.channels);
            continue;
        /* 处理管道事件 */
        if (msg.source_type == AUDIO_ELEMENT_TYPE_ELEMENT && msg.cmd == AEL_MSG_CMD_REPORT_STATUS) {
            audio_element_state_t el_state = audio_element_get_state(msg.source);
            if (el_state == AEL_STATE_FINISHED) {
                ESP_LOGI(TAG, "[ * ] 元素已完成: %s", (char *)msg.data);
    // 以下代码永远不会执行,但保留以供参考
    ESP_LOGI(TAG, "[ 14 ] 停止音频管道");
    audio_pipeline_stop(pipeline);
    audio_pipeline_wait_for_stop(pipeline);
    audio_pipeline_terminate(pipeline);
    /* 释放资源 */
    audio_pipeline_unregister(pipeline, opus_decoder);
    audio_pipeline_unregister(pipeline, i2s_writer);
    audio_pipeline_remove_listener(pipeline);
    audio_event_iface_destroy(evt);
    audio_pipeline_deinit(pipeline);
    audio_element_deinit(opus_decoder);
    audio_element_deinit(i2s_writer);
    esp_websocket_client_stop(client);
    esp_websocket_client_destroy(client);
