ESP32-C5 devout fails to flash
Davida
Postby Davida » Mon May 12, 2025 11:04 am
I am experiencing issues when attempting to flash an ESP32-C5 dev kit ()ESP32-C5-Devkit-1 V1.2 using the IDF command line tools.
The applications build correctly but always fails of be flashed. Debug details below and would greatly appreciate any help to resolve this issue.
C:\Espressif\frameworks\esp-idf-v5.4.1\examples\wifi\iperf>idf.py flash --force
Executing action: flash
Serial port COM6
Connecting....
Detecting chip type... ESP32-C5
Running ninja in directory C:\Espressif\frameworks\esp-idf-v5.4.1\examples\wifi\iperf\build
Executing "ninja flash"...
[1/5] C:\Windows\system32\cmd.exe /C "cd /D C:\Espressif\f...eworks/esp-idf-v5.4.1/examples/wifi/iperf/build/iperf.bin"
iperf.bin binary size 0xebcc0 bytes. Smallest app partition is 0x100000 bytes. 0x14340 bytes (8%) free.
[1/1] C:\Windows\system32\cmd.exe /C "cd /D C:\Espressif\f...5.4.1/examples/wifi/iperf/build/bootloader/bootloader.bin"
Bootloader binary size 0x57c0 bytes. 0x840 bytes (9%) free.
[4/5] C:\Windows\system32\cmd.exe /C "cd /D C:\Espressif\f...sp-idf-v5.4.1/components/esptool_py/run_serial_tool.cmake"
esptool.py --chip esp32c5 -p COM6 -b 460800 --before=default_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 80m --flash_size 2MB 0x2000 bootloader/bootloader.bin 0x10000 iperf.bin 0x8000 partition_table/partition-table.bin --force
esptool.py v4.8.1
Serial port COM6
Connecting....
WARNING: This chip doesn't appear to be a ESP32-C5 (chip magic value 0x5fd1406f). Probably it is unsupported by this version of esptool.
Chip is ESP32-C5 (revision v1.0)
Features: WiFi 6, BT 5, IEEE802.15.4
Crystal is 48MHz
MAC: 30:ed:a0:ff:fe:e4:6c:50
BASE MAC: 30:ed:a0:e4:6c:50
MAC_EXT: ff:fe
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00002000 to 0x00007fff...
Flash will be erased from 0x00010000 to 0x000fbfff...
Compressed 22464 bytes to 13688...
A fatal error occurred: Packet content transfer stopped (received 4072 bytes)
CMake Error at run_serial_tool.cmake:67 (message):
C:/Espressif/python_env/idf5.4_py3.11_env/Scripts/python.exe;;C:/Espressif/frameworks/esp-idf-v5.4.1/components/esptool_py/esptool/esptool.py;--chip;esp32c5
failed.
FAILED: CMakeFiles/flash C:/Espressif/frameworks/esp-idf-v5.4.1/examples/wifi/iperf/build/CMakeFiles/flash
C:\Windows\system32\cmd.exe /C "cd /D C:\Espressif\frameworks\esp-idf-v5.4.1\components\esptool_py && C:\Espressif\tools\cmake\3.30.2\bin\cmake.exe -D IDF_PATH=C:/Espressif/frameworks/esp-idf-v5.4.1 -D SERIAL_TOOL=C:/Espressif/python_env/idf5.4_py3.11_env/Scripts/python.exe;;C:/Espressif/frameworks/esp-idf-v5.4.1/components/esptool_py/esptool/esptool.py;--chip;esp32c5 -D SERIAL_TOOL_ARGS=--before=default_reset;--after=hard_reset;write_flash;@flash_args -D WORKING_DIRECTORY=C:/Espressif/frameworks/esp-idf-v5.4.1/examples/wifi/iperf/build -P C:/Espressif/frameworks/esp-idf-v5.4.1/components/esptool_py/run_serial_tool.cmake"
ninja failed with exit code 1, output of the command is in the C:\Espressif\frameworks\esp-idf-v5.4.1\examples\wifi\iperf\build\log\idf_py_stderr_output_5132 and C:\Espressif\frameworks\esp-idf-v5.4.1\examples\wifi\iperf\build\log\idf_py_stdout_output_5132
Error log contents
[1/5] C:\Windows\system32\cmd.exe /C "cd /D C:\Espressif\frameworks\esp-idf-v5.4.1\examples\wifi\iperf\build\esp-idf\esptool_py && C:\Espressif\python_env\idf5.4_py3.11_env\Scripts\python.exe C:/Espressif/frameworks/esp-idf-v5.4.1/components/partition_table/check_sizes.py --offset 0x8000 partition --type app C:/Espressif/frameworks/esp-idf-v5.4.1/examples/wifi/iperf/build/partition_table/partition-table.bin C:/Espressif/frameworks/esp-idf-v5.4.1/examples/wifi/iperf/build/iperf.bin"
[2/5] Performing build step for 'bootloader'
[1/1] C:\Windows\system32\cmd.exe /C "cd /D C:\Espressif\frameworks\esp-idf-v5.4.1\examples\wifi\iperf\build\bootloader\esp-idf\esptool_py && C:\Espressif\python_env\idf5.4_py3.11_env\Scripts\python.exe C:/Espressif/frameworks/esp-idf-v5.4.1/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x2000 C:/Espressif/frameworks/esp-idf-v5.4.1/examples/wifi/iperf/build/bootloader/bootloader.bin"
[3/5] No install step for 'bootloader'
[4/5] Completed 'bootloader'
[4/5] C:\Windows\system32\cmd.exe /C "cd /D C:\Espressif\frameworks\esp-idf-v5.4.1\components\esptool_py && C:\Espressif\tools\cmake\3.30.2\bin\cmake.exe -D IDF_PATH=C:/Espressif/frameworks/esp-idf-v5.4.1 -D SERIAL_TOOL=C:/Espressif/python_env/idf5.4_py3.11_env/Scripts/python.exe;;C:/Espressif/frameworks/esp-idf-v5.4.1/components/esptool_py/esptool/esptool.py;--chip;esp32c5 -D SERIAL_TOOL_ARGS=--before=default_reset;--after=hard_reset;write_flash;@flash_args -D WORKING_DIRECTORY=C:/Espressif/frameworks/esp-idf-v5.4.1/examples/wifi/iperf/build -P C:/Espressif/frameworks/esp-idf-v5.4.1/components/esptool_py/run_serial_tool.cmake"
esptool.py v4.8.1
Serial port COM6
Connecting....
Crystal is 48MHz
MAC_EXT: ff:fe
Uploading stub...
Running stub...
Stub running...
Changed.
A fatal error occurred: bootloader/bootloader.bin requires chip revision in range [v0.0 - v0.99] (this chip is revision v1.0). Use --force to flash anyway.
Davida
Re: ESP32-C5 devout fails to flash
Postby Davida » Wed May 14, 2025 9:38 pm
Espressif --- would request your support on getting started with your latest dual band wi-fi solution. As the board was pre-programmed with the blink app then there is a solution for flashing the devkit. Please advise.
Postby Sprite » Thu May 15, 2025 2:10 am
You're probably using a version of the chip that is not supported by the ESP-IDF version... maybe you can try the master branch?
Davida
Postby Davida » Thu May 15, 2025 8:01 am
I have followed the advice available online to use the master branch, also for the esp32c5 to use the --preview flag but the results are the same.
leven_073
Postby leven_073 » Sun May 18, 2025 12:43 pm
same err
same board
same prompt
luciarubio
Postby luciarubio » Wed May 21, 2025 8:16 am
Where did you buy it?
Grimkell
Postby Grimkell » Sat May 31, 2025 8:56 pm
I am having exactly the same problem, it looks like the IDF isn't compatible with the production silicon.
