Need help installing ESP-IDF on windows
Posted: Fri May 16, 2025 1:02 am
by surfdabbler
I have installed ESP-IDF as a VSCode extension. When I click on New Project, it gives the following error...
The "file" argument must be of type string. Received undefined
I've done the "Doctor command", and everything in the list shows undefined.
Here's an extract...
---------------------------------------------- ESP-IDF Extension for Visual Studio Code report ---------------------------------------------
OS undefined undefined undefined
System environment variable IDF_PYTHON_ENV_PATH
 undefined
System environment variable PATH
 undefined
System environment variable PYTHON
 undefined
Background info - I've spend more than 10 hours on this, and reinstalled it five times so far. I've tried from VSCode, and also tried installing ESP-IDF separately first, then linking it to the VS code extensions. I've tried express and advance installs, and tried installing in different directories, and in the default directories. I've spent hours trying to set the environment variables correctly and trying to fix the problems with the install. I'm a professional programmer with many years of experience with windows and embedded systems, but this development environment just isn't working. I would very much like to use the proper ESP-IDF environment in vscode, and not fall back to the arduino programming environment. Please help.
Re: Need help installing ESP-IDF on windows
Posted: Mon May 19, 2025 6:39 am
by nopnop2002
Can't install it even after following this page?
https://docs.espressif.com/projects/esp ... setup.html
VS-CODE extensions can be configured later.
https://docs.espressif.com/projects/vsc ... en/latest/
Posted: Mon May 19, 2025 8:12 am
by ok-home
hi
try rolling back to
ESP IDF VSCode Extension Release v1.9.0
Posted: Tue May 20, 2025 6:09 am
by surfdabbler
Thanks for the links and suggestions. I've got it working in PlatformIO for now (fairly straightforward install), so I'll probably continue with that, but if that doesn't work out, I will give these options a try. Thanks!
