ESP & Classic Bluetooth & SPP
Posted: Sun May 18, 2025 9:04 am
Hi
I use bt_spp_acceptor as template project for my application.
When creating a project, I couldn't compile it:
For some reason, at the configuration stage, I had to turn off the controller (disabled) in order for the Classic Bluetooth and SPP options to become available.
I use:
- ESP-IDF version: 6.0
- Espressif-IDE version: 3.4.0, Build id: 20250506-1512
- ESP-IDF Eclipse Plugin version: 3.4.0.202505061214
I ask for help from the competent community. What am I doing wrong?
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/main.c.obj
/home/vova/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/riscv32-esp-elf-gcc -DESP_PLATFORM -DIDF_VER=\"v5.5-dev-3703-gf9765d0316\" -DSOC_MMU_PAGE_SIZE=CONFIG_MMU_PAGE_SIZE -DSOC_XTAL_FREQ_MHZ=CONFIG_XTAL_FREQ -D_GLIBCXX_HAVE_POSIX_SEMAPHORE -D_GLIBCXX_USE_POSIX_SEMAPHORE -D_GNU_SOURCE -D_POSIX_READER_WRITER_LOCKS -I/home/vova/work/prj/esp/bt_spp_acceptor/build/config -I/home/vova/work/prj/esp/bt_spp_acceptor/main -I/home/vova/work/programs/esp/esp-idf/components/newlib/platform_include -I/home/vova/work/programs/esp/esp-idf/components/freertos/config/include -I/home/vova/work/programs/esp/esp-idf/components/freertos/config/include/freertos -I/home/vova/work/programs/esp/esp-idf/components/freertos/config/riscv/include -I/home/vova/work/programs/esp/esp-idf/components/freertos/FreeRTOS-Kernel/include -I/home/vova/work/programs/esp/esp-idf/components/freertos/FreeRTOS-Kernel/portable/riscv/include -I/home/vova/work/programs/esp/esp-idf/components/freertos/FreeRTOS-Kernel/portable/riscv/include/freertos -I/home/vova/work/programs/esp/esp-idf/components/freertos/esp_additions/include -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/include -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/include/soc -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/include/soc/esp32c6 -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/dma/include -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/ldo/include -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/debug_probe/include -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/mspi_timing_tuning/include -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/power_supply/include -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/port/esp32c6/. -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/port/esp32c6/include -I/home/vova/work/programs/esp/esp-idf/components/esp_hw_support/port/esp32c6/private_include -I/home/vova/work/programs/esp/esp-idf/components/heap/include -I/home/vova/work/programs/esp/esp-idf/components/heap/tlsf -I/home/vova/work/programs/esp/esp-idf/components/log/include -I/home/vova/work/programs/esp/esp-idf/components/soc/include -I/home/vova/work/programs/esp/esp-idf/components/soc/esp32c6 -I/home/vova/work/programs/esp/esp-idf/components/soc/esp32c6/include -I/home/vova/work/programs/esp/esp-idf/components/soc/esp32c6/register -I/home/vova/work/programs/esp/esp-idf/components/hal/platform_port/include -I/home/vova/work/programs/esp/esp-idf/components/hal/esp32c6/include -I/home/vova/work/programs/esp/esp-idf/components/hal/include -I/home/vova/work/programs/esp/esp-idf/components/esp_rom/include -I/home/vova/work/programs/esp/esp-idf/components/esp_rom/esp32c6/include -I/home/vova/work/programs/esp/esp-idf/components/esp_rom/esp32c6/include/esp32c6 -I/home/vova/work/programs/esp/esp-idf/components/esp_rom/esp32c6 -I/home/vova/work/programs/esp/esp-idf/components/esp_common/include -I/home/vova/work/programs/esp/esp-idf/components/esp_system/include -I/home/vova/work/programs/esp/esp-idf/components/esp_system/port/soc -I/home/vova/work/programs/esp/esp-idf/components/esp_system/port/include/riscv -I/home/vova/work/programs/esp/esp-idf/components/esp_system/port/include/private -I/home/vova/work/programs/esp/esp-idf/components/riscv/include -I/home/vova/work/programs/esp/esp-idf/components/lwip/include -I/home/vova/work/programs/esp/esp-idf/components/lwip/include/apps -I/home/vova/work/programs/esp/esp-idf/components/lwip/include/apps/sntp -I/home/vova/work/programs/esp/esp-idf/components/lwip/lwip/src/include -I/home/vova/work/programs/esp/esp-idf/components/lwip/port/include -I/home/vova/work/programs/esp/esp-idf/components/lwip/port/freertos/include -I/home/vova/work/programs/esp/esp-idf/components/lwip/port/esp32xx/include -I/home/vova/work/programs/esp/esp-idf/components/lwip/port/esp32xx/include/arch -I/home/vova/work/programs/esp/esp-idf/components/lwip/port/esp32xx/include/sys -I/home/vova/work/programs/esp/esp-idf/components/bt/common/osi/include -I/home/vova/work/programs/esp/esp-idf/components/bt/common/api/include/api -I/home/vova/work/programs/esp/esp-idf/components/bt/common/btc/profile/esp/blufi/include -I/home/vova/work/programs/esp/esp-idf/components/bt/common/btc/profile/esp/include -I/home/vova/work/programs/esp/esp-idf/components/bt/common/hci_log/include -I/home/vova/work/programs/esp/esp-idf/components/bt/common/ble_log/include -I/home/vova/work/programs/esp/esp-idf/components/bt/host/bluedroid/api/include/api -I/home/vova/work/programs/esp/esp-idf/components/bt/common/tinycrypt/include -I/home/vova/work/programs/esp/esp-idf/components/bt/common/tinycrypt/port -I/home/vova/work/programs/esp/esp-idf/components/esp_timer/include -I/home/vova/work/programs/esp/esp-idf/components/esp_wifi/include -I/home/vova/work/programs/esp/esp-idf/components/esp_wifi/include/local -I/home/vova/work/programs/esp/esp-idf/components/esp_wifi/wifi_apps/include -I/home/vova/work/programs/esp/esp-idf/components/esp_wifi/wifi_apps/nan_app/include -I/home/vova/work/programs/esp/esp-idf/components/esp_event/include -I/home/vova/work/programs/esp/esp-idf/components/esp_phy/include -I/home/vova/work/programs/esp/esp-idf/components/esp_phy/esp32c6/include -I/home/vova/work/programs/esp/esp-idf/components/esp_netif/include -I/home/vova/work/programs/esp/esp-idf/components/nvs_flash/include -I/home/vova/work/programs/esp/esp-idf/components/esp_partition/include -march=rv32imac_zicsr_zifencei -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=unused-but-set-variable -Wno-error=deprecated-declarations -Wextra -Wno-error=extra -Wno-unused-parameter -Wno-sign-compare -Wno-enum-conversion -gdwarf-4 -ggdb -nostartfiles -Og -fno-shrink-wrap -fmacro-prefix-map=/home/vova/work/prj/esp/bt_spp_acceptor=. -fmacro-prefix-map=/home/vova/work/programs/esp/esp-idf=/IDF -fstrict-volatile-bitfields -fno-jump-tables -fno-tree-switch-conversion -std=gnu17 -Wno-old-style-declaration -MD -MT esp-idf/main/CMakeFiles/__idf_main.dir/main.c.obj -MF esp-idf/main/CMakeFiles/__idf_main.dir/main.c.obj.d -o esp-idf/main/CMakeFiles/__idf_main.dir/main.c.obj -c /home/vova/work/prj/esp/bt_spp_acceptor/main/main.c
/home/vova/work/prj/esp/bt_spp_acceptor/main/main.c:17:10: fatal error: esp_bt.h: No such file or directory
17 | #include "esp_bt.h"
compilation terminated.
I use:
