ESP32 Stuck After Enabling Flash Encryption (Secure Boot NOT Enabled)
Vaibhav02
Postby Vaibhav02 » Tue May 20, 2025 7:01 am
Hi everyone,
I'm working on ESP32 with ESP-IDF v5.3 and have enabled Flash Encryption in development mode.
What’s Working:
  • Flashing works fine (idf.py flash)
  • Flash encryption efuse (FLASH_CRYPT_CNT = 1) is set
  • Secure Boot V1 and V2 are not enabled (ABS_DONE_0 = 0, ABS_DONE_1 = 0)
The Problem:
After flashing, the serial monitor shows:
--- esp-idf-monitor 1.5.0 on \\.\COM5 115200
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
But there is no output from the chip – not even bootloader logs.
What I’ve Tried:
Verified efuses with espefuse.py summary
Full flash erase + clean build + idf.py flash
Different COM ports, USB cables, baud rates
My Questions:
  • Is this behavior expected when Flash Encryption is enabled but a wrong/unencrypted image is flashed?
  • Could the device hang due to a bad encryption key or mismatched flash image?
  • What is the best recovery strategy when Flash Encryption is enabled and device is unresponsive?
Any help would be greatly appreciated. Thanks!
tori@labjack
Re: ESP32 Stuck After Enabling Flash Encryption (Secure Boot NOT Enabled)
Postby tori@labjack » Mon Jun 22, 2026 9:23 pm
Hello, I know this is a super late response, but I had this same issue.
I found out that I had set: CONFIG_BOOT_ROM_LOG_ALWAYS_OFF=y which sets an eFuse (in my case it set DIS_USB_JTAG to 1) which had disabled all logging. I ended up having to use a different ESP32 :(
Users browsing this forum: Baidu [Spider], PerplexityBot, PetalBot, Semrush [Bot] and 3 guests
