On ESP01S the led (GPIO2) light on at initial SPI flash read
handyman
Postby handyman » Tue May 27, 2025 6:24 am
Hello good morning everyone, this is my first post, let's see how it goes. I'm experimenting with a simple ESP-01S board managing a pair of relays. There are already several hardware solutions for this. The one I'm using uses the GPIO-0 and GPIO-2 pins (the blue LED). By default, GPIO-2 flashes short during boot. I solved this problem by placing a capacitor on the base of the relay transistor. My first version was made under the Arduino platform. In this environment, the hardware seems to work correctly, but I have problems with the TCP/IP stack and sometimes it stops responding correctly. In the second version (the current one), I'm testing the ESP8266 RTOS (ESP-IDF v3.4). Here I have stability in the system, it manages the WEB server correctly and sends alert emails without problems. The only problem I have is when booting, system reads the code from the SPI FLASH. And it seems that it is during this reading that the LED (GPIO-2) activates again. This behavior is different from what is observed on the Arduino platform. I wonder if it's possible to modify RTOS to eliminate this LED flashing during the initial code reading. Thanks for everything.
Users browsing this forum: Qwantbot and 4 guests
