Problems with using PCNT.
Microzod
Postby Microzod » Sun Jun 15, 2025 10:14 pm
Hello.
I am trying to make use of the PCNT module, in my code I have two libraries that each use PCNT, they work just fine when I test them separated but once put into the same sketch one of the libraries stop working.
Is there any known issues with using driver/pulse_cnt.h?
FYI, I am using an esp32-s3 and all in all my sketch is trying to utilize 3 of 4 pcnt units.
The first library is a publicly available library called RotaryEncoderPCNT
Regards
horace99
Re: Problems with using PCNT.
Postby horace99 » Fri Jun 20, 2025 6:23 pm
I have used the RotaryEncoderPCNT library for reading a QEI encoder module without problems
what is the other library?
could you implement a program using the two libraries which demonstrates the problem?
lbernstone
Postby lbernstone » Sun Jun 22, 2025 6:43 pm
The linked library is properly keeping track of the units used. Perhaps the other one isn't. Try switching the order of initialization.
Microzod
Postby Microzod » Tue Oct 14, 2025 10:54 pm
I think it has something to do with keeping track of which units that are available or not, in the end I solved this by taking that rotary encoder library code and combining it with my own code. It is a really messy solution but at least everything works when I set up everything from within a single class instance.
Users browsing this forum: Google [Bot], Qwantbot and 2 guests
