I have created my first custom PCB with an ESP32.
I received the PCBs today, and they don't work. I can flash the firmware. I tried it with WLED and the typical "hello_world" example. But it won't start. Nothing is shown on the serial monitor.
Everything looks fine; the power is ok, but it's not starting.
I can get the chip info and the mac info, but it never runs the program.
For WLED, the wifi AP is never created, and for the "hello_world" nothing is shown in the monitor.
Is there any way to find out what is happening?
If I reset the device, what I see is this:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0x0 (DOWNLOAD(USB/UART0))
Saved PC:0x40041a76
waiting for downloadCode: Select all
esptool.py v4.8.1
Serial port /dev/ttyACM0:
Connecting...
Detecting chip type... ESP32-S3
Connected to ESP32-S3 on /dev/ttyACM0:
Chip type: ESP32-S3 (QFN56) (revision v0.2)
Features: Wi-Fi, BT 5 (LE), Dual Core + LP Core, 240MHz, Embedded Flash 8MB (GD)
Crystal frequency: 40MHz
USB mode: USB-Serial/JTAG
MAC: f0:f5:bd:51:cd:3c
Uploading stub flasher...
Running stub flasher...
Stub flasher running.
Flash Memory Information:
Manufacturer: c8
Device: 4017
Detected flash size: 8MB
Flash type set in eFuse: quad (4 data lines)
Flash voltage set by eFuse: 3.3V
Hard resetting via RTS pin...
