[ESP32-S3] Continuous Reboot After Flashing Larger Firmware – Tried Everything
sdeveloper
Postby sdeveloper » Mon Jun 16, 2025 6:20 pm
Hi everyone,
I’m facing a persistent reboot issue on one of my ESP32-S3 boards after flashing a larger firmware binary. Here’s a breakdown of the problem:
🔧 What’s Happening
After flashing my project (which worked earlier), the board continuously reboots with:
Guru Meditation Error: Core 1 panic'ed (LoadProhibited)
Backtrace points to invalid memory access—likely due to bad pointer or heap exhaustion.
✅ What I’ve Tried
Flashed Blink Sketch: Works perfectly—board hardware appears okay for small binaries.
Same Firmware on Another Board: No issues. Confirms code is not at fault.
Erased Flash via esptool.py:
esptool.py --chip esp32 --port /dev/ttyUSB0 erase_flash
Manually Reset NVS Using Code:
cpp
#include <nvs_flash.h>
nvs_flash_erase();
nvs_flash_init();
Used Espressif’s Flash Download Tool:
Flashed bootloader.bin (0x0000), partitions.bin (0x8000), and firmware.bin (0x10000)
No luck—the board still reboots.
Tested Multiple USB Cables and Ports: Stable power supply confirmed.
❗ The Catch
Once I flash the buggy firmware, even reverting to previous working builds won’t fix the reboot—unless it’s a trivial sketch like Blink. It's like something persists and interferes with booting.
🔍 What I Suspect
Flash memory corruption or unreadable NVS
Damaged or write-protected flash sector
Misaligned partition table after bad flash
Board-specific hardware failure (but no visible damage)
🆘 What I’m Hoping For
Any advice on:
Checking flash chip health or ID
Forcing a full flash overwrite (including factory partition?)
Recovering from possible bootloader or NVS corruption
Verifying NVS and partition health via command-line tools or logs
Thanks in advance for any help! I’m happy to share boot logs, backtrace, or decoded .elf addresses if it helps debug this further.
Users browsing this forum: Bytespider, ChatGPT-User, YisouSpider and 3 guests
