Arduino as a component
lucasmiti1
Postby lucasmiti1 » Wed Jun 18, 2025 2:43 pm
Hello all,
I'm trying to get a program to work in ESP-IDF, using arduino as a component. I followed the guide here: https://docs.espressif.com/projects/ard ... onent.html but it isn't working.
Here's the procedure I'm following:
  • Create the example project:
idf.py create-project-from-example "espressif/arduino-esp32^3.0.2:hello_world"
  • Set the board target:
idf.py set-target esp32c3
  • Add components to the project:
mkdir -p components && \
cd components && \
git clone https://github.com/espressif/arduino-esp32.git arduino && \
cd arduino && \
git submodule update --init --recursive && \
cd ../.. && \
idf.py menuconfig
  • Swap some file extensions from .c to .cpp:
-In main folder rename file main.c to main.cpp.
-In main folder open file CMakeLists.txt and change main.c to main.cpp as described below.
  • Turn on "Autostart Arduino setup and loop on boot" from menuconfig
Program used:
//file: main.cpp
#include "Arduino.h"
void setup(){
  while(!Serial){
    ; // wait for serial port to connect
void loop(){
    Serial.println("loop");
    delay(1000);
  • Then I flash and monitor the board:
idf.py flash
idf.py monitor
However, "Hello world" is not being printed.
Things tried:
-I've flashed the board without Arduino as a component, and the example works.
-I've cloned arduino-ESP32 version 3.2.0 into components.
-I've also tried using ESP-IDF appmain() instead of void setup and loop.
Any ideas on what I might be missing or doing incorrectly?
Users browsing this forum: Semrush [Bot] and 4 guests
