idf.py menuconfig ignore keyboard input in powershell/cmd on windows 10
Posted: Mon Jul 07, 2025 7:08 pm
Hello everyone! Have some troubles with menuconfig - it ignores everithing that happened on my keyboard. So i can't navigate and configure my project. It builds, it starts - but thats all. My ESP IDF version 6.0, python venv is 3.12. Menu config tool called from project folder [idf.py menuconfig].
Log that i catch form cmd.exe
E:\gitRepositories\smartgit\esp32_st7789_focus_st_dash>idf.py menuconfig
Executing action: menuconfig
Running ninja in directory E:\gitRepositories\smartgit\esp32_st7789_focus_st_dash\build
Executing "ninja menuconfig"...
[0/1] Re-running CMake...-- Minimal build - ON
-- Building ESP-IDF components for target esp32
NOTICE: Processing 1 dependencies:
NOTICE: [1/1] idf (6.0.0)
-- Project sdkconfig file E:/gitRepositories/smartgit/esp32_st7789_focus_st_dash/sdkconfig
-- Compiler supported targets: xtensa-esp-elf
-- USING O3
-- App "esp32_st7789_focus_st_dash" version: 0d7cd38
-- Adding linker script E:/gitRepositories/smartgit/esp32_st7789_focus_st_dash/build/esp-idf/esp_system/ld/memory.ld
-- Adding linker script E:/gitRepositories/smartgit/esp32_st7789_focus_st_dash/build/esp-idf/esp_system/ld/sections.ld.in
-- Adding linker script C:/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script C:/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.api.ld
-- Adding linker script C:/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script C:/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script C:/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script C:/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.libc-funcs.ld
-- Adding linker script C:/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-reent-funcs.ld
-- Adding linker script C:/esp/esp-idf/components/soc/esp32/ld/esp32.peripherals.ld
-- Components: app_update bootloader bootloader_support cxx efuse esp_app_format esp_bootloader_format esp_common esp_driver_gpio esp_driver_spi esp_hw_support esp_mm esp_partition esp_pm esp_rom esp_security esp_system esp_timer esptool_py fre
Maybe anyone know how to fix this issue or where i should look for...
-- USING O3
