ESP32-DEVKIT-V1 Guru Meditation error
bytebandit
Postby bytebandit » Fri Jul 25, 2025 8:03 pm
Hello, i was working with my ESP32 car and i forgot to remove the ESP32 completely to code it (it had no effect on anything) but it was working fine and now this code (that used to work) is giving me a guru meditation error
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include <Adafruit_NeoPixel.h>
#include <ESP32Servo.h>
// Motor pins
#define IN1 12
#define IN2 14
#define IN3 27
#define IN4 26
// NeoPixel pins
#define LED_PIN    19
#define LED_COUNT  16
// Servo pin
#define SERVO_PIN  33
Adafruit_NeoPixel ring(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
Servo myServo;
enum MotorDirection { STOP, FORWARD, BACKWARD, LEFT, RIGHT };
MotorDirection currentDirection = STOP;
unsigned long lastAnimationUpdate = 0;
const unsigned long animationInterval = 25;
uint8_t ledOffset = 0;
unsigned long servoActionTime = 0;
int targetServoAngle = 90;
BLECharacteristic* pCharacteristic;
const char* SERVICE_UUID = "12345678-1234-1234-1234-25f07f20f25";
const char* CHARACTERISTIC_UUID = "abcd1234-5678-90ab-cdef-25f07f20f25";
void policeBeaconAnimation() {
  if (millis() - lastAnimationUpdate >= animationInterval) {
    lastAnimationUpdate = millis();
    ledOffset = (ledOffset + 1) % LED_COUNT;
    ring.clear();
    for (int i = 0; i < LED_COUNT; i++) {
      int pos = (i + ledOffset) % LED_COUNT;
      if (i < 8) ring.setPixelColor(pos, ring.Color(255, 0, 0)); // Red
      else ring.setPixelColor(pos, ring.Color(0, 0, 255));       // Blue
    ring.show();
void setMotorPinsLow() {
  digitalWrite(IN1, LOW);
  digitalWrite(IN2, LOW);
  digitalWrite(IN3, LOW);
  digitalWrite(IN4, LOW);
void moveForward() {
  digitalWrite(IN1, HIGH);
  digitalWrite(IN3, HIGH);
  currentDirection = FORWARD;
void moveBackward() {
  digitalWrite(IN2, HIGH);
  digitalWrite(IN4, HIGH);
  currentDirection = BACKWARD;
void turnLeft() {
  currentDirection = LEFT;
void turnRight() {
  currentDirection = RIGHT;
class MyCallbacks : public BLECharacteristicCallbacks {
  void onWrite(BLECharacteristic* pCharacteristic) override {
    String value = pCharacteristic->getValue();
    if (value.length() >= 7 &&
        (uint8_t)value[1] == 0x01 &&
        (uint8_t)value[4] == 0x02) {
      uint16_t btn = ((uint8_t)value[6] << 8) | (uint8_t)value[5];
      Serial.printf("Button state: 0x%04X\n", btn);
      bool movement = false;
      if (btn & 0x0100) { moveForward(); movement = true; }
      else if (btn & 0x0200) { moveBackward(); movement = true; }
      else if (btn & 0x0400) { turnLeft(); movement = true; }
      else if (btn & 0x0800) { turnRight(); movement = true; }
      if (btn & 0x0001) {
        targetServoAngle = 180;
        servoActionTime = millis();
      } else if (btn & 0x0002) {
        Serial.println("Servo CLOSE");
        targetServoAngle = 0;
      if (!movement) setMotorPinsLow();
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  pinMode(IN3, OUTPUT);
  pinMode(IN4, OUTPUT);
  setMotorPinsLow(); // initialize all motor pins LOW
  ring.begin();
  ring.setBrightness(80);
  ring.show();
  myServo.attach(SERVO_PIN);
  myServo.write(90); // Neutral position
  BLEDevice::init("TC-ATO");
  BLEServer* pServer = BLEDevice::createServer();
  BLEService* pService = pServer->createService(SERVICE_UUID);
  pCharacteristic = pService->createCharacteristic(
    CHARACTERISTIC_UUID,
    BLECharacteristic::PROPERTY_WRITE | BLECharacteristic::PROPERTY_WRITE_NR
  pCharacteristic->setCallbacks(new MyCallbacks());
  pCharacteristic->addDescriptor(new BLE2902());
  pService->start();
  BLEAdvertising* pAdvertising = BLEDevice::getAdvertising();
  pAdvertising->addServiceUUID(SERVICE_UUID);
  pAdvertising->setScanResponse(true);
  pAdvertising->setMinPreferred(0x06);
  pAdvertising->setMinPreferred(0x12);
  BLEDevice::startAdvertising();
  Serial.println("Ready! BLE active. Waiting for commands...");
  policeBeaconAnimation();
  // Update servo position only when triggered
  if (servoActionTime && millis() - servoActionTime >= 15) {
    myServo.write(targetServoAngle);
  // Debug motor pins state every second
  static unsigned long lastDebug = 0;
  if (millis() - lastDebug > 1000) {
    lastDebug = millis();
    Serial.print("Motor pins states - IN1: ");
    Serial.print(digitalRead(IN1));
    Serial.print(", IN2: ");
    Serial.print(digitalRead(IN2));
    Serial.print(", IN3: ");
    Serial.print(digitalRead(IN3));
    Serial.print(", IN4: ");
    Serial.println(digitalRead(IN4));
Does anyone know how to fix it? It says it's due to a null something exception but i think the
is incorrect because normally it's
 std::string value ...
but it didn't work so i made it a String. Also is there any chance i could have fried it?
Thanks in advance for the help,
bytebandit
Users browsing this forum: Bing [Bot], Semrush [Bot] and 3 guests
