Re: ESP32-S3 UNO : USB Connector detached - SOLVED
Posted: Sat Jul 26, 2025 2:56 pm
Is it possible to program a ESP32-S3 via the Rx &Tx pins?
I have a ESP32-S3 UNO and the USB connector has come off!
I have tried to reattach it, but to no avail.
The reason it became detached is due to the poorly designed mechanical fixing of the USB-C connector.
It is soldered to the board, BUT the fixing pin depth is less than the PCB thickness.
I suspect that this will be a problem with all of the USB-C board connectors.
So, any tips as how to program this board without using the USB port?
