managed_components folder names
eskibrew
Postby eskibrew » Wed Aug 13, 2025 12:58 pm
Using ESP-IDF with the vscode extension.
If I add the lvgl component from the registry to my project using
idf.py add-dependency "lvgl/lvgl^9.3.0"
and then build, the managed_component directory is created and the lvgl library is added however instead of adding as lvgl/lvgl, it gets added as lvgl__lvgl.
This then has the problem where it's not being included via #include "lvgl/lvgl.h"
Is there a way to change the directory name to avoid the prepended lvgl__ ? - I've had a look at the format of idf_component.yml but that does not seem to give me a way to specify it.
I have a similar issue with esp_lcd_touch which gets added under managed_components as espressif__esp_lcd_touch
I feel like I'm missing something obvious but can't see it...
Users browsing this forum: Amazon [Bot], Baidu [Spider], Bytespider, Google [Bot], Semrush [Bot] and 3 guests
