How to use std::string on esp32
apalazzi
Postby apalazzi » Sun Aug 17, 2025 6:44 pm
I'm programming an esp32 board with C++/FreeRTOS and so far things are progressing; however there's one thing that seem to cause all sort of issues like stack corruption and guru meditations, and that is std::string.
I read that rising the stack size could maybe help. but how do I do that for the main task?
IS there something else that I should do to use std::String without crashing the application?
Andrea
Re: How to use std::string on esp32
Postby Sprite » Mon Aug 18, 2025 1:58 am
In ESP-IDF, you can set the main task size using menuconfig. In Arduino, I think you can use something like SET_LOOP_TASK_STACK_SIZE(16*1024);
Users browsing this forum: Baidu [Spider], ChatGPT-User and 1 guest
