Is __thread type modifier supported by ESP-IDF's toolchain?
vvb333007
Contact:
Postby vvb333007 » Wed Aug 20, 2025 2:53 am
Hello everyone!
I know FreeRTOS supports TLS. However it is not clear if I can use "__thread" type modifier to make my global variables to be thread-specific? Or should I use API provided by FreeRTOS and manage my global variables myself?
What I am trying to do: I am converting some application to ESP-IDF. Application uses global variables, so I want to make these variables to be "per thread" variables
Thank you!
Thanks!
Slava.
vvb333007
Contact:
Re: Is __thread type modifier supported by ESP-IDF's toolchain?
Postby vvb333007 » Wed Aug 20, 2025 3:03 am
Oh, I should be making a test by myself, before asking.
Anyway.
Yes, __thread type specifier works as it should.
PS:
No, started to celebrate too early.
When I added third variable with __thread (other two was pointer and unsigned int) the ESP32 goes into infinite reboot with StoreProhibited exception. The problems is that I don't even use this variable.
It is defined as
static __thread const char *prompt = "prompt";
The exception decoded to absolute nonsence:
Decoding stack results
0x4200e20b: HardwareSerial::_uartEventTask(void*) at C:\Users\WINDOWS\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.0\cores\esp32\HardwareSerial.cpp:268
0x42018dce: spi_flash_hal_init at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/hal\spi_flash_hal.c:143
0x40376556: call_start_cpu0 at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/xtensa/include\xt_utils.h:41
It is nonsence, because my application does not use class HardwareSerial, it is a pure C code which uses printf()
As soon as I remove __thread specifier, or variable definition completely - it works.
Any ideas?
__thread is buggy?
@ESP_igrr , @Sprite
Thanks!
Slava.
vvb333007
Contact:
Postby vvb333007 » Fri Sep 05, 2025 3:43 pm
Oh ok, I investigated the issue and found something interesting:
If you have __thread (_Thread_local) variable, which you try to assign (or read) in a function with "constructor" attribute
whole thing will crash:
static __thread void *sample;
void __attribute__((constructor)) __init_sample() {
  sample = NULL;
My guess that it happens because .ctor section is processed before any task is created. Is this specific to xtensa toolchain or it is normal behaviour?
Thanks!
Slava.
Users browsing this forum: Google [Bot] and 2 guests
