Raw PDM with more than two microphones
anton_skr
Postby anton_skr » Thu Aug 28, 2025 6:20 pm
I am interested in using the raw PDM mode on the I2S peripheral with 6 microphones (3 data lines).
I can get the raw PDM data of one data line (two microphones) using the following configuration:
i2s_pdm_rx_config_t pdm_rx_cfg = {
	.clk_cfg = {
		.sample_rate_hz = 3072000,
		.clk_src = I2S_CLK_SRC_DEFAULT,
		.mclk_multiple = I2S_MCLK_MULTIPLE_256,
		.dn_sample_mode = I2S_PDM_DSR_8S,
		.bclk_div = 13,
	.slot_cfg = {
		.data_bit_width = I2S_DATA_BIT_WIDTH_16BIT,
		.slot_bit_width = I2S_SLOT_BIT_WIDTH_AUTO,
		.slot_mode = I2S_SLOT_MODE_STEREO,
		.slot_mask = 0b11,
		.data_fmt = I2S_PDM_DATA_FMT_RAW
	.gpio_cfg = {
		.clk = GPIO_NUM_4,
		.dins = {
			GPIO_NUM_21,
			GPIO_NUM_13,
			GPIO_NUM_14
		.invert_flags = {
			.clk_inv = false,
ESP_ERROR_CHECK(i2s_channel_init_pdm_rx_mode(rx_chan, &pdm_rx_cfg));
ESP_ERROR_CHECK(i2s_channel_enable(rx_chan));
However when I try to activate the other two data lines by setting
.slot_mask = 0b111111
nothing changes, I am still getting data only for the first data line.
Is raw PDM supported with more than one data line? How can I configure it?
Best regards,
Anton
Vvvoid
Re: Raw PDM with more than two microphones
Postby Vvvoid » Fri Oct 17, 2025 8:53 am
why there are 3 gpio in your .din? isnt just two ?
anton_skr
Postby anton_skr » Fri Oct 17, 2025 3:36 pm
I have 6 microphones, so I need 3 data lines. Maybe that's not possible.
But it's ok, I gave up on this and went with a different path.
But thanks for checking.
Vvvoid
Postby Vvvoid » Wed Oct 29, 2025 9:05 am
shit it happens to me, I have 8 microphones, but i only get 4 data, the other four data values are constantly unstable.i dont know why...
Users browsing this forum: Bytespider, Qwantbot and 1 guest
