SIM800l at-commands are echoed back.
Lartzu
Postby Lartzu » Sun Aug 31, 2025 5:46 pm
I hope that some of you can give some advices for me.
The problem is that I'm not get any reasonable replies back to ESP from SIM800L module
//#define TINY_GSM_MODEM_SIM7080
#define TINY_GSM_MODEM_SIM800
#include <HardwareSerial.h>
#include <TinyGsmClient.h>
#define SerialMon Serial
HardwareSerial gsmSerial(2);
TinyGsm modem(gsmSerial);
TinyGsmClient client(modem);
  // Set console baud rate
  SerialMon.begin(9600);
  delay(10);
  SerialMon.println("Wait...");
  gsmSerial.begin(9600, SERIAL_8N1, 16, 17); //
  SerialMon.println("Initializing modem...");
  //modem.restart();
  modem.init();
  delay(2000);
  String modemInfo = modem.getModemInfo();
  SerialMon.print("Modem Info: ");
  SerialMon.println(modemInfo);
  SerialMon.println("Sending AT command...");
  delay (1000);
  String IMEI = modem.getIMEI();
  Serial.print ("IMEI:");
  Serial.println (IMEI);
The first line (black) is connected to PIN17 and line 2. is directly connected to RXD in SIM800L module
esp32 17 -> SIM800L RXD
SIM800L TXD-> esp32 16
---- added ----
The common ground for SIM and ESP cleared the situation. Now is working....
ahsrabrifat
Re: SIM800l at-commands are echoed back.
Postby ahsrabrifat » Mon Sep 01, 2025 1:40 pm
Hello, have you shorted the GND pins? What power supply are you using for the SIM800L module?
Lartzu
Postby Lartzu » Mon Sep 01, 2025 6:21 pm
The common ground for SIM and ESP cleared the situation. Now it is working....
I have an other question related to this.... how to use Data only USB-cable between ESP - WIN (data, and ground connected.)
Users browsing this forum: trendictionbot and 4 guests
