Our application is a BLE HOGP (HID Over GATT Profile) remote control with target current draw <200uA.
BLE HOGP Support
Can you please advise whether BLE HOGP example application(s) are available for the ESP32? If so, please forward relevant URL(s).
Device Selection
We don't require Wi-Fi, so perhaps the ESP32-H2-MINI-1 modules are suitable for our application. ESP32-H2-MINI-1 light-sleep current is <100uA, so if the ESP32 is mostly in this mode, e.g. wake every 10 seconds for <100ms at <10mA, total current drawn would be <200uA. However, this relies on a BLE connection being maintained in light-sleep.
Forum Search
This post: viewtopic.php?t=44584 states:
. However, following implementation, the current draw was found to be too high.Using an external 32kHz crystal you should be able to keep Bluetooth 'connected' during light sleep.
Low Power Requirement
Can you please advise whether our power requirement can be satisfied using ESP32-H2-MINI-1 devices? If so, please advise necessary configuration settings.
Thank you.
