Question about Board with built in Oled?
Hobby65
Postby Hobby65 » Sat Sep 06, 2025 2:24 pm
I ordered an ESP32 board with a built-in OLED.
It hasn't arrived yet. Does anyone know this board?
https://de.aliexpress.com/item/10050073 ... pt=glo2deu
Can it be controlled with the Arduino software?
Does anyone have a sample code?
Thank you very much.
Hans
ahsrabrifat
Re: Question about Board with built in Oled?
Postby ahsrabrifat » Sat Sep 06, 2025 5:49 pm
For boards like the WeMos Lolin32 OLED, the built-in OLED uses GPIO 5 (SDA) and GPIO 4 (SCL), not the ESP32's default I²C pins (21 & 22)
Your code should explicitly set up I²C to use the board's pins:
#include <Wire.h>
Wire.begin(5, 4);  // SDA = 5, SCL = 4
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
  Wire.begin(5, 4);
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C, false, false)) {
    Serial.println(F("OLED init failed"));
    while (1);
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  display.println("Hello, ESP32 OLED!");
  display.display();
Users browsing this forum: Baidu [Spider], Bing [Bot], DuckDuckGo [Bot], Google [Bot], ok-home and 0 guests
