Faulty board?
Posted: Mon Sep 08, 2025 9:30 am
by sixie6e
I purchased the ESP32 Development Board WiFi & Bluetooth Dual Cores Wireless Module CH340 Driver Support Integrated PCB Antenna with 0.96" OLED Display for Arduino/Micropython, USB Interface 34GPIOs
which is now listed as: 5PCS D1 Mini ESP32 ESP-WROOM-32 WLAN WiFi + Bluetooth IoT Development Board Kit Dual Cores CPU Module USB Interface Compatible with Arduino IDE NodeMC https://www.amazon.com/dp/B0D8Y6B9C5
I cannot get it into download mode. I have tried different cables, different computers, CLI, Thonny, ArduinoIDE, different combinations and timing of BOOT, EN, and powering on. I have tried adding capacitors to EN and GND and 3v3/VIN and GND. Different baud rates result in different invalid head of packet addresses. I'm thinking I have a faulty board. I would like to still be able to use it somehow.
Here's CLI output:
sixie6e@distherapy:~$ python3 -m esptool erase_flash
esptool.py v4.9.0
Found 1 serial ports
Serial port /dev/ttyUSB0
Connecting......................................
/dev/ttyUSB0 failed to connect: Failed to connect to Espressif device: Invalid head of packet (0x53): Possible serial noise or corruption.
sixie6e@distherapy:~$ python3 -m esptool --baud 230400 erase_flash
esptool.py v4.9.0
/dev/ttyUSB0 failed to connect: Failed to connect to Espressif device: Invalid head of packet (0x1B): Possible serial noise or corruption.
sixie6e@distherapy:~$ python3 -m esptool --baud 9600 erase_flash
esptool.py v4.9.0
/dev/ttyUSB0 failed to connect: Failed to connect to Espressif device: No serial data received.
sixie6e@distherapy:~$ python3 -m esptool --trace --baud 9600 erase_flash
esptool.py v4.9.0
Connecting...TRACE +0.000 command op=0x08 data len=36 wait_response=1 timeout=0.100 data=
0707122055555555 5555555555555555 | ... UUUUUUUUUUUU
5555555555555555 5555555555555555 | UUUUUUUUUUUUUUUU
55555555 | UUUU
TRACE +0.000 Write 46 bytes:
c000082400000000 0007071220555555 | ...$........ UUU
5555555555555555 5555555555c0 | UUUUUUUUUUUUU.
TRACE +0.029 Read 1 bytes: 38
TRACE +0.000 Read invalid data: 38
TRACE +0.000 Remaining data in serial buffer:
318786e5804c304e a74a21a111087c2a | 1....L0N.J!...|*
0abd22950af3 | .."...
sixie6e@distherapy:~$ miniterm
--- Available ports:
--- 1: /dev/ttyUSB0 'USB Serial'
--- Enter port index or full name: 1
--- Miniterm on /dev/ttyUSB0 9600,8,N,1 ---
--- unknown menu character ' ' --
--- exit ---
sixie6e@distherapy:~$ miniterm /dev/ttyUSB0 115000
--- Miniterm on /dev/ttyUSB0 115000,8,N,1 ---
--- exit ---
Re: Faulty board?
Posted: Tue Sep 09, 2025 10:10 am
by Sprite
If you connect to the port in miniterm (115200 baud), then reset the board, do you see a signon message? (e.g. ' ets Jul 29 2019 12:21:46') If not, yeah, your board likely is broken.
Re: Faulty board?
Posted: Tue Sep 09, 2025 12:31 pm
by sixie6e
Nope. Just blank. Not even garbled serial data.
Re: Faulty board?
Posted: Wed Sep 10, 2025 2:33 am
by Sprite
Yeah, then it's likely dead.
Re: Faulty board?
Posted: Wed Sep 10, 2025 2:09 pm
by sixie6e
This is what makes me think it isn't:
Re: Faulty board?
Posted: Thu Sep 11, 2025 7:30 pm
by sixie6e
Okay, so what I did was place that 10mf cap, not directly from EN to GND, but to the negative rail of the breadboard. From their site, I chose an earlier version of the .bin for ESP32. Then in Thonny, I chose MicroPython(generic) instead of MicroPython(ESP32).
The board is not lost!
Re: Faulty board?
Posted: Fri Sep 12, 2025 12:11 am
by Sprite
That's odd, I'd expect the negative rail of your breadboard to be at exactly the same potential as GND... Good that you got it working, though.
Re: Faulty board?
Posted: Wed Oct 15, 2025 1:35 pm
by sixie6e
It wasn't the breadboard, either, and the capacitor only solved part of the problem:
https://www.instagram.com/reel/DPzZjmPDvbM/
Re: Faulty board?
Posted: Wed Oct 15, 2025 7:11 pm
by sixie6e
Serial monitor:
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5148
load:0x40078000,len:12880
load:0x40080400,len:3484
entry 0x40080630
I (539) cpu_start: Pro cpu up.
I (539) cpu_start: Application information:
I (539) cpu_start: Compile time: Sep 2 2020 03:04:09
I (543) cpu_start: ELF file SHA256: 0000000000000000...
I (549) cpu_start: ESP-IDF: v4.0.1
I (554) cpu_start: Starting app cpu, entry point is 0x40082830
I (0) cpu_start: App cpu up.
I (564) heap_init: Initializing. RAM available for dynamic allocation:
I (571) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (577) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
I (583) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (589) heap_init: At 3FFBDB5C len 00000004 (0 KiB): DRAM
I (595) heap_init: At 3FFCAD78 len 00015288 (84 KiB): DRAM
I (601) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (608) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (614) heap_init: At 4009E9D8 len 00001628 (5 KiB): IRAM
I (620) cpu_start: Pro cpu start user code
I (639) spi_flash: detected chip: generic
I (639) spi_flash: flash io: dio
I (640) cpu_start: Starting scheduler on PRO CPU.
MicroPython v1.13 on 2020-09-02; ESP32 module with ESP32
Type "help()" for more information.
