Esp32S3 : Is it possible to modify the USB string descriptors when using USB-SERIAL-JTAG ?
Posted: Fri Sep 19, 2025 11:05 am
by ThomasESP32
Good afternoon,
I am programming an Esp32S3 using ESP-IDF.
I am using the USB-Serial-JTAG driver in order to send/receive datas over the USB Bus with the following functions :
- usb_serial_jtag_driver_install : In order to install the usb_serial_jtag driver.
- usb_serial_jtag_read_bytes : In order to Read datas.
- usb_serial_jtag_write_bytes : In order to Write datas.
The problem is that I would like to modify some string descriptors of the USB Device.
Especially, iProduct (String descriptor 2) and iManufacturer (String descriptor 1).
Is it possible to modify the content of these two string descriptors using the USB-SERIAL-JTAG interface ?
Thank you for your help on the subject,
Best regards,
Thomas TRUILHE
Re: Esp32S3 : Is it possible to modify the USB string descriptors when using USB-SERIAL-JTAG ?
Posted: Sat Sep 20, 2025 6:31 am
by Sprite
No, all the descriptors are stored in (unchangable) ROM. You can use USB-OTG where you can set those as you desire.
