ESP32S2 Crypted OTA bin err uploading: Could Not Activate The Firmware
Posted: Sat Sep 27, 2025 8:57 pm
Hey.
- Lolin S2 mini
- sketch compiled with Arduino 1.8.19 && 3.3.1 framework
- sketch have Wifi.softAP and OTA functions
I prepare ota file, use this bin:
ota_key.txt containing 32byte as OTA_KEY.
When I upload an encrypted image, I get an error "Could Not Activate The Firmware"
This err generating by esp_ota_set_boot_partition(_partition)
Help me figure out where I went wrong.
Without Update.setupCrypt and without image encryption, everything updates well.
- Lolin S2 mini
#include <Update.h>
const uint8_t OTA_KEY[32] = {'0','v','R','u','e','o','B','n','S','v','t','B','P','l','e','Q','4','D','s','0','1','q','Q','U','5','g','x','7','Z','u','3','5'};
#define OTA_ADDRESS 0x0
#define OTA_CFG 0x0
#define OTA_MODE U_AES_DECRYPT_ON
void start_ota() {
if(!Serial) Serial.begin(115200);
server.on("/ota", HTTP_GET, []() { server.sendHeader("Connection", "close"); server.send(200, "text/html", otahtml); });
server.on("/upl_fw", HTTP_POST, []() {
server.send(200, "text/plain", (Update.hasError()) ? String(Update.getError()) : "OK");
if(Update.hasError()) Update.printError(Serial);
server.handleClient();
delay(100);
resetModule();
{ esp_task_wdt_reset();
delay(1);
HTTPUpload &upload = server.upload();
if (upload.status == UPLOAD_FILE_START) {
Serial.printf("upd: %s\n", upload.filename.c_str());
if (!Update.begin(UPDATE_SIZE_UNKNOWN)) { Update.printError(Serial); } // start with max available size
} else if (upload.status == UPLOAD_FILE_WRITE) {
//secure
if (!Update.setupCrypt(OTA_KEY, OTA_ADDRESS, OTA_CFG, OTA_MODE)) {
Serial.println("Update.setupCrypt failed!");
//flashing firmware
if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) { Update.printError(Serial); }
Serial.print(F("."));
} else if (upload.status == UPLOAD_FILE_END) {
if (Update.end(true)) { Serial.println("upd_succ\nreboot\n"); LITTLEFS.remove("/config.txt"); } // true to set the size to the current progress && clear old config
else { Update.printError(Serial); }
}Code: Select all
espsecure.exe encrypt_flash_data -k ota_key.txt --flash_crypt_conf 0x0 -a 0x0 -o %%f.ota %%fWhen I upload an encrypted image, I get an error "Could Not Activate The Firmware"
