Crash
bruleherman
Crash
Postby bruleherman » Sat Oct 04, 2025 2:02 pm
I don't understand why it crash, even in emulator.
Even in setup() loop. I use arduino IDE, it's not support debug mode.
I always code into C/C++, and I don't see anything wrong.
Few bit help please. Code is working when I rewrite for Linux.
Regards,
electric_line_oscilloscope.zip
(2.04 KiB) Downloaded 23 times
Re: Crash
Postby Sprite » Sun Oct 05, 2025 3:08 am
Normally, I'd ask for you to get the backtrace and decode that, in this case that probably would have lead you to the issue, but here it's obvious enough for me to spot it immediately:
#define BUFFERSIZE 256
int16_t buffer[BUFFERSIZE];//one value each ms
memset(buffer,0,1024*2);
Could be that there are more bugs later on, I didn't look that closely.
Users browsing this forum: Amazon [Bot], Bytespider and 2 guests
