SPI Maximum speed
ESP_Sprite
Re: SPI Maximum speed
Postby ESP_Sprite » Thu Oct 11, 2018 2:43 am
Note the crystal doesn't really matter; the ESP32 normally uses a PLL to derive the CPU frequency from this, then divides the CPU frequency by an applicable number to get the 80MHz APB clk.
Vader_Mester
Contact:
Postby Vader_Mester » Thu Oct 11, 2018 10:41 am
anakyr wrote:I'm 100% sure that I have a 40MHz crystal. Check attachment too. I will try first to include SPI_DEVICE_NO_DUMMY in order to ignore this checking, as the error message in red is saying. If it doesn't work, I will go to the registers :)
Why did I forget about the GPIO MUX?
You can route your SPI directly to pins without using the GPIO MUX matrix, so with it you can achieve higher speeds. I think all your answers are in fact in the red warning message.
There are 2 types of programmer people: The Expert programmer and The Smart programmer
The Expert programmer easily writes any code from scratch.
The Smart programmer uses his google/github powers first ;)
anakyr
Postby anakyr » Thu Oct 11, 2018 12:15 pm
Thanks a lot for the answers. Using this dummy flag I was able to produce 40 MHz at the MOSI.
Users browsing this forum: Google [Bot] and 23 guests
