Esp-idf I2S Mic + SD card Record High Pitch Noise
Michalios
Postby Michalios » Mon Oct 13, 2025 2:28 pm
Hello every one,
I started modified the example given in esp-idfv5.5.1 I2S_recorder.
I am using the ESP32-S3-Touch-LCD-1.46B https://www.waveshare.com/wiki/ESP32-S3 ... ic_Diagramdevelopment board by waveshare.
It uses the msm261s4030h0 I2S mic and an SD card without the use of CS, as it is connected to an ioExtender.
The projects builds, and creates the .wav file in the sd card. I recognise that I am speaking but it is inaudible due to high pitch noise. I saw from the mics' datasheet that the frequency plane is from 100-10KHz, so I decreased the sampling freq to 22kHz. I did try to change the bit sampling to 8,16,24,32 but not much changed in the output.
I also tried recording when I powered it though USB cable and the Lipo, no difference.
What could the problem be ?
Thanks a lot.
 * SPDX-FileCopyrightText: 2021-2024 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Unlicense OR CC0-1.0
#include <stdio.h>
#include <string.h>
#include <sys/unistd.h>
#include <sys/stat.h>
#include "sdkconfig.h"
#include "esp_log.h"
#include "esp_err.h"
#include "esp_system.h"
#include "esp_vfs_fat.h"
#include "freertos/task.h"
#include "driver/i2s_std.h"
#include "driver/gpio.h"
#include "sdmmc_cmd.h"
#include "format_wav.h"
#include "driver/sdmmc_host.h"
static const char *TAG = "i2s_rec_example";
#define CONFIG_EXAMPLE_BIT_SAMPLE 24
#define CONFIG_EXAMPLE_SAMPLE_RATE 44100 / 2
#define CONFIG_EXAMPLE_SDMMC_CLK_GPIO 14
#define CONFIG_EXAMPLE_SDMMC_CMD_GPIO 17
#define CONFIG_EXAMPLE_SDMMC_D0_GPIO 16
#define CONFIG_EXAMPLE_I2S_DATA_GPIO 39
#define CONFIG_EXAMPLE_I2S_CLK_GPIO 15
#define CONFIG_EXAMPLE_I2S_WS_GPIO 2
#define CONFIG_EXAMPLE_REC_TIME 5
#define NUM_CHANNELS (1)
#define SD_MOUNT_POINT "/sdcard"
#define SAMPLE_SIZE (CONFIG_EXAMPLE_BIT_SAMPLE * 1024)
#define BYTE_RATE (CONFIG_EXAMPLE_SAMPLE_RATE * (CONFIG_EXAMPLE_BIT_SAMPLE / 8)) * NUM_CHANNELS
// Global variables
sdmmc_card_t *card;
i2s_chan_handle_t rx_handle = NULL;
static int16_t i2s_readraw_buff[SAMPLE_SIZE];
size_t bytes_read;
void mount_sdcard(void)
    esp_err_t ret;
    esp_vfs_fat_sdmmc_mount_config_t mount_config = {
        .format_if_mount_failed = true,
        .max_files = 5,
        .allocation_unit_size = 16 * 1024};
    ESP_LOGI(TAG, "Initializing SD card using SD/MMC mode");
    sdmmc_host_t host = SDMMC_HOST_DEFAULT();
    sdmmc_slot_config_t slot_config = SDMMC_SLOT_CONFIG_DEFAULT();
    slot_config.width = 1; // 1-line SD mode
    slot_config.clk = CONFIG_EXAMPLE_SDMMC_CLK_GPIO;
    slot_config.cmd = CONFIG_EXAMPLE_SDMMC_CMD_GPIO;
    slot_config.d0 = CONFIG_EXAMPLE_SDMMC_D0_GPIO;
    slot_config.d1 = -1;
    slot_config.d2 = -1;
    slot_config.d3 = -1;
    slot_config.flags |= SDMMC_SLOT_FLAG_INTERNAL_PULLUP;
    ret = esp_vfs_fat_sdmmc_mount(SD_MOUNT_POINT, &host, &slot_config, &mount_config, &card);
    ESP_LOGI(TAG, "Filesystem mounted successfully");
    sdmmc_card_print_info(stdout, card);
void record_wav(uint32_t rec_time)
    const int I2S_BUFFER_SIZE = 4096;
    uint8_t *i2s_read_buf = (uint8_t *)malloc(I2S_BUFFER_SIZE);
    ESP_LOGI(TAG, "Opening file to record");
    FILE *f = fopen(SD_MOUNT_POINT "/record.wav", "wb");
    if (f == NULL)
        ESP_LOGE(TAG, "Failed to open file for writing");
        free(i2s_read_buf);
        return;
    // --- Create WAV Header
    uint32_t sample_rate = CONFIG_EXAMPLE_SAMPLE_RATE;
    uint16_t bits_per_sample = CONFIG_EXAMPLE_BIT_SAMPLE;
    uint32_t byte_rate = sample_rate * (bits_per_sample / 8);
    uint32_t data_size = byte_rate * rec_time;
    const wav_header_t wav_header =
        WAV_HEADER_PCM_DEFAULT(data_size, bits_per_sample, sample_rate, 1);
    fwrite(&wav_header, 1, sizeof(wav_header_t), f);
    // --- Recording Loop ---
    uint32_t total_bytes_written = 0;
    while (total_bytes_written < data_size)
        size_t bytes_read = 0;
        i2s_channel_read(rx_handle, i2s_read_buf, I2S_BUFFER_SIZE, &bytes_read, portMAX_DELAY);
        if (bytes_read > 0)
            fwrite(i2s_read_buf, 1, bytes_read, f);
            total_bytes_written += bytes_read;
    ESP_LOGI(TAG, "Recording done! Total bytes: %d", total_bytes_written);
    fclose(f);
    free(i2s_read_buf);
    ESP_LOGI(TAG, "File written on SDCard");
    esp_vfs_fat_sdcard_unmount(SD_MOUNT_POINT, card);
    ESP_LOGI(TAG, "Card unmounted");
void init_microphone(void)
    i2s_chan_config_t chan_cfg = I2S_CHANNEL_DEFAULT_CONFIG(I2S_NUM_0, I2S_ROLE_MASTER);
    ESP_ERROR_CHECK(i2s_new_channel(&chan_cfg, NULL, &rx_handle));
    i2s_std_config_t std_cfg = {
        .clk_cfg = {
            .sample_rate_hz = CONFIG_EXAMPLE_SAMPLE_RATE,
            .clk_src = I2S_CLK_SRC_DEFAULT,
            .mclk_multiple = I2S_MCLK_MULTIPLE_384,
        .slot_cfg = I2S_STD_MSB_SLOT_DEFAULT_CONFIG(I2S_DATA_BIT_WIDTH_24BIT, I2S_SLOT_MODE_MONO),
        .gpio_cfg = {
            .mclk = I2S_GPIO_UNUSED,
            .bclk = CONFIG_EXAMPLE_I2S_CLK_GPIO,
            .ws = CONFIG_EXAMPLE_I2S_WS_GPIO,
            .din = CONFIG_EXAMPLE_I2S_DATA_GPIO,
            .dout = I2S_GPIO_UNUSED,
    ESP_ERROR_CHECK(i2s_channel_init_std_mode(rx_handle, &std_cfg));
    ESP_ERROR_CHECK(i2s_channel_enable(rx_handle));
void app_main(void)
    printf("I2S microphone recording example start\n--------------------------------------\n");
    mount_sdcard();
    init_microphone();
    ESP_LOGI(TAG, "Starting recording for %d seconds!", CONFIG_EXAMPLE_REC_TIME);
    record_wav(CONFIG_EXAMPLE_REC_TIME);
    ESP_ERROR_CHECK(i2s_channel_disable(rx_handle));
    ESP_ERROR_CHECK(i2s_del_channel(rx_handle));
Users browsing this forum: Amazon [Bot], Bing [Bot], ChatGPT-User, PetalBot, Qwantbot and 1 guest
