httpd exposed TaskHandle_t ?
Baldhead
Postby Baldhead » Tue Oct 21, 2025 1:07 am
I would like to know if it is possible to get the TaskHandle_t from the httpd task, if it is only a single task.
I created a centralized task ( "gatekeeper task" ) to access shared data, like (set() and get() functions, all encapsulated functions.
I want to take advantage of this same task to implement some way of notifying/routing information that has changed.
So, i need httpd TaskHandle_t, but I'm open to other suggestions.
I would like to do something like this:
typedef struct
    server_state_t data;
    my_server_state_command_t cmd_id;
    TaskHandle_t task_handle;
}mss_task_dev_t;
static QueueHandle_t mss_data_queue = NULL;
mss_data_queue = xQueueCreate( 4, sizeof(mss_task_dev_t) );
// gatekeeper task call this function.
static void task_send_notification_to_interested_tasks(const mss_task_dev_t* mss_msg)
    ESP_LOGI(MY_SERVER_STATE_TAG, LOG_USER1("[%s:] Notify Tasks.", __func__));
    // Message came from the server ?
    if (mss_msg->task_handle == httpd_task)
        // test if any data has changed, just notify if the data has changed.
        // notify hardware task.
        // notify ui task.
        // notify all client connected to the server, except the one that sent the information (I need to see how to identify this yet).
    // Message came from the gui ?
    if (mss_msg->task_handle == gui_task)
        // update_clients_state();  // notify all clients connected to the server.
// Lib interface
void set_server_state(server_state_t st)
    mss_task_dev_t var;
    memset(&var, 0, sizeof(mss_task_dev_t));
    var.cmd_id = CMD_SET_ALL_STRUCT;
    var.data = st;
    var.task_handle = xTaskGetCurrentTaskHandle();  // handle of the task that called this function.
    BaseType_t ret = xQueueSend(mss_data_queue, (void *)&var, 0);
    if (ret == errQUEUE_FULL)
        ESP_LOGW(MY_SERVER_STATE_TAG, "[%s] Queue [mss_data_queue] full, cannot send command to task [%s], returning without blocking the task.", __func__, pcTaskGetName(my_server_state_task_Handle) );
        return;
Thank's.
MicroController
Re: httpd exposed TaskHandle_t ?
Postby MicroController » Tue Oct 21, 2025 9:37 am
Using task handles may not be the best approach to identify the source of an event: The handles' values may change, e.g. when the HTTPd is restarted in response to network changes. Pre-defined constant values could avoid issues with this; which suggests that the IDF event loop may be a viable alternative for your use case.
Baldhead
Postby Baldhead » Wed Oct 22, 2025 6:51 pm
It's a bit strange that I have to use an identification tag in the set() function, for example:
// Lib interface
void set_server_state(server_state_t st, task_identification tag)
    mss_task_dev_t var;
    var.data = st;
    var.tag = tag;
    //var.task_handle = xTaskGetCurrentTaskHandle();  // handle of the task that called this function.
        return;
Users browsing this forum: Amazon [Bot], Bing [Bot], ChatGPT-User, PetalBot, Qwantbot and 1 guest
