various question for First boot/flash Start to the ESP_Module_Testboard
Posted: Tue Dec 15, 2015 11:17 pm
by rudi ;-)
hi
before work on First Start with electric on the ready soldered ESP board i ask before,
because we have only one module and i would work long time in beta ( greetings to Kolban, i soldered, but i do not know, did it fine too) :mrgreen:
which process you do for first start?
soldering
3.3 -> Pin name 3.3
GND ->Pin name GND
3.3 -> Pin name EN
( do we need to connect GPIO15 and other ( GPIO02, GPIO00 ) like ESP8266?)
which is the the HW RST pin (Chip Pin 47? ) on the ESP_Module_Testboard?
have we a table for boot mechanism / processing available just in time?
Re: various question for First boot/flash Start to the ESP_Module_Testboard
Posted: Tue Dec 15, 2015 11:51 pm
by rudi ;-)
Can we HW reset the Modul?
question HW RST.JPG (49.7 KiB) Viewed 13029 times
txs
Posted: Wed Dec 16, 2015 12:23 am
by rojer9
i think EN can be used to reset the device.
that said, i'm not having much success flashing the device, so take it for what it's worth...
Posted: Thu Dec 31, 2015 9:51 am
by ESP_Greg
rudi, can the below boot mode configuration help you out?
Posted: Tue Jan 05, 2016 7:12 am
by rudi ;-)
txs, yes - this helps.
btw:
we have the Chip_En pin
this pin is no reset pin. if the pin goes Vcc + then the SoC is 100 prozent active
if the pin goes Low, the SoC works in which Mode?
deep deep sleep? ( only RTC is working )
deep sleep? ( Modem is off, CPU is working )
sleep ( Modem is listen, trigger to wake up with Res 14k ? as a RST
can / have we later in ESP32 a real RST Pin ( reboot function in SSC ) ?
txs
is there are nice Mode for watching Pin ISR in deep deep sleep?
Posted: Wed Jan 06, 2016 2:32 am
by Sprite
The Chip_En pin is the same as on the ESP8266: if it's pulled low, the chip is entirely disabled, which is functionally the same as it being in reset state. That's why you can use it as a reset pin; it has the same effect. Yes, there is a very nice mode for watching pins (and A/D, and capacative sensors, and...) in deep sleep; unfortunately we don't have the documentation for it ready as of now.
