Running ESP32 unit tests
Wynand95
Postby Wynand95 » Thu Oct 23, 2025 9:05 am
Using esp-idf v5.2.5 on Windows, I'm trying to run the example unit tests on my ESP32-C6-WROOM-1 board but after I build and flash the unit test app it seems to me like the unit tests are not actually running. Am I missing something? I'm trying to introduce some unit testing into a project and I figured I'd start with the examples provided. I tried multiple examples but none seemed to run, the last one being:
https://github.com/espressif/esp-idf/bl ... est_test.c
The output I'm getting from the monitor is:
I (289) main_task: Started on CPU0
I (289) main_task: Calling app_main()
#### Executing one test by its name #####
#### Running tests with [mean] tag #####
#### Running tests without [fails] tag #####
#### Running all the registered tests #####
#### Starting interactive test menu #####
--- Warning: Writing to serial is timing out. Please make sure that your application supports an interactive console and that you have picked the correct console for serial communication.
In the repo's README.md I see that the output should be different and that I should be seeing the tests running.
https://github.com/espressif/esp-idf/bl ... /README.md
