Serial.begin() leads to build errors
Posted: Sat Nov 15, 2025 1:15 pm
by Seysin
As soon as I add
Serial.begin(115200);
in my project i get a bunch of build errors (see below). Without that line everything works as it should. Other Arduino functions work fine. In an empty project just for testing Arduino Serial printing it also works without a problem. Tried to solve it with Claude but Claude is just making up non-existing CMakeLists- or SDKConfig-Options.
Here are the errors:
[7/9] Linking CXX executable lvgl_demo_v9.elf
FAILED: lvgl_demo_v9.elf
C:\WINDOWS\system32\cmd.exe /C "cd . && D:\.espressif\tools\riscv32-esp-elf\esp-14.2.0_20241119\riscv32-esp-elf\bin\riscv32-esp-elf-g++.exe -march=rv32imafc_zicsr_zifencei_xesppie -mabi=ilp32f -nostartfiles -march=rv32imafc_zicsr_zifencei_xesppie -mabi=ilp32f    -Wl,--cref -Wl,--defsym=IDF_TARGET_ESP32P4=0 -Wl,--Map=C:/Users/<USER>/ESP-IDF-Projects/<PROJECT>/build/lvgl_demo_v9.map -Wl,--no-warn-rwx-segments -Wl,--orphan-handling=warn -fno-rtti -fno-lto -Wl,--gc-sections -Wl,--warn-common -T rom.api.ld -T esp32p4.peripherals.ld -T esp32p4.rom.ld -T esp32p4.rom.api.ld -T esp32p4.rom.rvfp.ld -T esp32p4.rom.wdt.ld -T esp32p4.rom.systimer.ld -T esp32p4.rom.version.ld -T esp32p4.rom.libc.ld -T esp32p4.rom.libc-suboptimal_for_misaligned_mem.ld -T esp32p4.rom.newlib.ld -T memory.ld -T sections.ld -Wl,--enable-non-contiguous-regions @CMakeFiles\lvgl_demo_v9.elf.rsp -o lvgl_demo_v9.elf && cd ."
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.periph_spinlock' from `esp-idf/esp_hw_support/libesp_hw_support.a(periph_ctrl.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.rtc_spinlock' from `esp-idf/esp_hw_support/libesp_hw_support.a(rtc_module.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.spinlock_rtc_deep_sleep' from `esp-idf/esp_hw_support/libesp_hw_support.a(sleep_modes.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.s_psram_best_delayline' from `esp-idf/esp_hw_support/libesp_hw_support.a(mspi_timing_by_dqs.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.s_psram_best_phase' from `esp-idf/esp_hw_support/libesp_hw_support.a(mspi_timing_by_dqs.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.mux' from `esp-idf/esp_hw_support/libesp_hw_support.a(regi2c_ctrl.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.pau_context.0' from `esp-idf/esp_hw_support/libesp_hw_support.a(pau_regdma.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.xKernelLock' from `esp-idf/freertos/libfreertos.a(tasks.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.lock_init_spinlock' from `esp-idf/newlib/libnewlib.a(locks.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.s_keys_lock' from `esp-idf/pthread/libpthread.a(pthread_local_storage.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.s_time_update_lock' from `esp-idf/esp_timer/libesp_timer.a(esp_timer_impl_common.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.s_registered_select_lock' from `esp-idf/esp_driver_uart/libesp_driver_uart.a(uart_vfs.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.uart_selectlock' from `esp-idf/esp_driver_uart/libesp_driver_uart.a(uart.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.s_registered_select_lock' from `esp-idf/esp_driver_usb_serial_jtag/libesp_driver_usb_serial_jtag.a(usb_serial_jtag_vfs.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.chip_type' from `esp-idf/espressif__esp_hosted/libespressif__esp_hosted.a(transport_drv.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.g_h' from `esp-idf/espressif__esp_hosted/libespressif__esp_hosted.a(port_esp_hosted_host_os.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.session_mobile' from `esp-idf/main/libmain.a(lv_demo_widgets_analytics.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.session_tablet' from `esp-idf/main/libmain.a(lv_demo_widgets_analytics.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.session_desktop' from `esp-idf/main/libmain.a(lv_demo_widgets_analytics.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.grid_main_col_dsc.5' from `esp-idf/main/libmain.a(lv_demo_widgets_profile.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.grid1_col_dsc.3' from `esp-idf/main/libmain.a(lv_demo_widgets_shop.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata._ZL13tx_timeout_ms' from `esp-idf/espressif__arduino-esp32/libespressif__arduino-esp32.a(HWCDC.cpp.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.mux.5' from `esp-idf/joltwallet__littlefs/libjoltwallet__littlefs.a(esp_littlefs.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.__compound_literal.32' from `esp-idf/espressif__esp_lcd_st7701/libespressif__esp_lcd_st7701.a(esp_lcd_st7701_rgb.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: --enable-non-contiguous-regions discards section `.sdata.__compound_literal.31' from `esp-idf/espressif__esp_lcd_st7701/libespressif__esp_lcd_st7701.a(esp_lcd_st7701_rgb.c.obj)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/lib/rv32imafc_zicsr_zifencei/ilp32f/no-rtti\libstdc++.a(new_opvnt.o)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/lib/rv32imafc_zicsr_zifencei/ilp32f/no-rtti\libstdc++.a(eh_term_handler.o)'
D:/.espressif/tools/riscv32-esp-elf/esp-14.2.0_20241119/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld.exe: error: Total discarded sections size is 3586 bytes
collect2.exe: error: ld returned 1 exit status
 *  The terminal process "d:\.espressif\tools\ninja\1.12.1\ninja.EXE" terminated with exit code: 1.
I'm using ESP-IDF v5.5.1 under VSCode with Arduino as a Component v3.3.2. Build is for ESP32-P4.
Re: Serial.begin() leads to build errors
Posted: Sun Nov 16, 2025 10:25 am
by horace99
can you post the program which gave the error messages?
