ADC: SENS_MEASn_DONE_SAR register bit not clearing after next measurement started (ESP32)
fermino
Postby fermino » Fri Nov 21, 2025 10:16 am
Hey there!
I've been trying to use the ADC using the HAL layer only and I've run into this interesting behavior that I can't quite figure out. For the purposes of the post I will base everything on the peripherals/adc/oneshot_read example as it's what I've been debugging lately to make sure I'm not missing anything. There are references to the relevant lines of code so that the reasoning is easier to follow. I am using an ESP32 and I have tested it with ESP-IDF 5.5 and the latest master from github.
After a oneshot conersion is initiated in adc_oneshot_hal_convert [1], there is a loop that waits on adc_oneshot_ll_get_event [2] to return true, which in turn returns the value of SENS_MEASn_DONE_SAR, a read-only bit that according to the technical reference manual [3] (registers 31.6 and 31.21) indicates that a conversion has finished.
The issue I'm observing is that this bit is not cleared, ever. Not after the conversion result register is read, and not after the next conversion is started.
Granted, there's nothing in the documentation that mentions the clearing of this bit, but I find it weird that it wouldn't given the IDF code specificly waiting on it. It would effectively mean that after the first conversion is finished any call to adc_oneshot_ll_get_event (to that unit) would return true, making the driver in turn just use whatever is on the conversion result register at that time.
Am I understanding something wrong? For my specific use case I'm leaning towards using the continous driver as I need to trigger a conversion and read it asynchronously, but nonetheless I thought it was worth asking.
I have been using a JTAG debugger setting breakpoints on those lines, and also setting watches for those register bits. One question I still have is whether the ADC clock is stopped or if it keeps running, which would make for weird results. In any case, I have not been able to have the register ever read 0 after the first conversion, so there's that.
As a side remark, the adc_oneshot_ll_clear_event and adc_oneshot_ll_enable calls right before the conversion is started inside adc_oneshot_hal_convert are effectively bogus in the ESP32 (they're empty).
[1] https://github.com/espressif/esp-idf/bl ... hal.c#L155
[2] https://github.com/espressif/esp-idf/bl ... _ll.h#L464
[3] https://documentation.espressif.com/esp ... ual_en.pdf
Users browsing this forum: trendictionbot and 4 guests
