I have two PCs running Linux and I'd like to access the first one and interact with it via a serial console. Neither of the PCs have a serial console. I have an ESP32-S3 (actually 3 incase I ruin any one of them). So I thought I'd setup the Kernel parameters to redirect logging to the ESP32-S3 serial port (labelled COM on the physical device), hoping that might work.
I tried adding the below to the Kernel boot parameters via `/etc/default/grub` and regenerated the boot menu and initramfs, and then rebooted.
`console=tty0 console=ttyACM0,115200`
I used `ttyACM0` as this is what appears in `/dev` when I attach the device to my system.
Once I've rebooted nothing appears on the ESP32-S3 serial console.
1. Does anyone know what I'm doing wrong?
2. Is one ESP32-S3 sufficient to do what I'm trying to achieve?
3. I suspect the parameters I'm passing to the command line aren't correct because I could find hardly any results where people are using "`console=tty0 console=ttyACM0,115200`".
Is this possible?
Kind regards,
Bana
ESP32-S3: As a Linux Console TTY
Users browsing this forum: Amazon [Bot], Bing [Bot], ChatGPT-User, Google [Bot], PerplexityBot, Qwantbot and 1 guest
