read读取sdcard数据速率太低怎么办
Posted: Fri Nov 28, 2025 7:33 am
第一次做esp32,有没有大佬解答下
背景:
esp32c6
esp-idf环境
esp版本:5.3.1
代码:
sdcard初始化
读取数据
时钟节拍的频率我设置成了1000;及一个tick大约1ms;end_tick-start_tick大约为30ms(30个ticks)左右;
问题:
max_freq_khz最大频率为20MHz,理论上传输速率应该是10MB/s;但是读取30k的数据耗时30ms;速率为1MB/s;这和最大速率相差太多了吧?
请问是什么原因?怎么解决?
背景:
esp32c6
esp-idf环境
esp版本:5.3.1
代码:
sdcard初始化
void SD_card_Init(void)
esp_vfs_fat_sdmmc_mount_config_t mount_config =
.format_if_mount_failed = false, //If the hook fails, create a partition table and format the SD card
.max_files = 5, //Maximum number of open files
.allocation_unit_size = 512 //Similar to sector size
spi_bus_config_t bus_cfg =
.mosi_io_num = PIN_NUM_MOSI,
.miso_io_num = PIN_NUM_MISO,
.sclk_io_num = PIN_NUM_CLK,
.quadwp_io_num = -1,
.quadhd_io_num = -1,
.max_transfer_sz = 4000, //Maximum transfer size
ESP_ERROR_CHECK_WITHOUT_ABORT(spi_bus_initialize(SD_SPI, &bus_cfg, SDSPI_DEFAULT_DMA));
sdspi_device_config_t slot_config = SDSPI_DEVICE_CONFIG_DEFAULT();
slot_config.gpio_cs = PIN_NUM_CS;
slot_config.host_id = SD_SPI;
sdmmc_host_t host = SDSPI_HOST_DEFAULT();
host.slot = SD_SPI;
host.max_freq_khz = SDMMC_FREQ_DEFAULT;//20MHz
host.flags = host.flags | SDMMC_HOST_FLAG_4BIT;
ESP_ERROR_CHECK_WITHOUT_ABORT(esp_vfs_fat_sdspi_mount(SDlist, &host, &slot_config, &mount_config, &card));
if(card != NULL)
sdmmc_card_print_info(stdout, card); //Print out the card information
printf("practical_size:%.2fG\n",(float)(card->csd.capacity)/2048/1024);//g
example_test_file_operations();
}Code: Select all
FILE *f = fopen(path, "rb");
if (f == NULL)
printf("path:Read Wrong path\n");
return ESP_ERR_NOT_FOUND;
uint32_t unlen = 1024*30;
start_tick = xTaskGetTickCount();
uint32_t poutLen = fread((void *)pxbuf,1,unlen,f);
end_tick = xTaskGetTickCount();问题:
请问是什么原因?怎么解决?
