Negative voltage at GPIO pin
cwford
Postby cwford » Tue Dec 02, 2025 5:32 am
Measuring RPMs of my boat's engine via PWM from the alternator. Current circuit design gives me -12 millivolts at startup/idle but no negative voltage in normal operating RPM range. Is -12 millivolts still too much negative voltage at an ESP32 GPIO pin?
Understand that negative voltage at a GPIO pin can damage an Esp32. But how much negative voltage is too much? Can't seem to find any specs on that.
TIA,
Clyde
Re: Negative voltage at GPIO pin
Postby Sprite » Tue Dec 02, 2025 7:52 am
That's in the datasheet. You didn't specify what ESP32 you have (so make sure to check the datasheet for your specific chip) but generally voltages down to -0.3V are acceptable.
Users browsing this forum: PetalBot and 2 guests
