Can't get the ESP32 CAM Module to work
Posted: Sun Dec 07, 2025 6:49 am
greetings ya'll,
I've the following products:
https://makerbazar.in/products/esp32-ca ... era-module
https://adiy.in/shop/rp2040-type-c-pico-board-adiy-fly/
https://www.amazon.in/Robodo-W26-Wirele ... PY8GSZD15V
[it's not of the same brand but, it's the same board
My plan was to use the RP2040 as a pico-uart-bridge [ i did try using the uf2 from the repo as well as writing one myself in Arduino IDE and extracted the compiled binary ] and then connect my esp32 cam board with it for flashing it. I did encounter this error at last, in the attachment. If you could help me with this or let me know if I could use the ESP8266 module with the ESP32 cam module and make that work.
I'm starting with capturing a photo and save it to the SD card, then the next step is to get a live feed running onto a web portal locally accessible on my network.
