ESP32 vs ESP32-S3 Deep Sleep Behavior
Posted: Sun Dec 21, 2025 7:57 am
I have been using ESP32 modules for my application that sometimes requires a certain GPIO to be pulled up during deep sleep. The only function that I have needed to call to accomplish this is gpio_pullup_en. This has worked with no issues to maintain the pin state throughout deep sleep and wakeups.
I am making an update to my design and am considering changing to a ESP32-S3 module, mainly due the USB-OTG support. I obtained a ESP32-S3 development board to test its functionality and compare to my original boards before making the change in my actual design. One major difference I immediately noticed is that gpio_pullup_en is not sufficient to maintain the pulled-up state during deep sleep. I found that gpio_hold_en was required to keep the pin high during sleep, even though I previously did not need to do this.
I don't understand the reason for this difference. I found the documentation for the gpio_hold_en function even more confusing, as it seems to imply that that the function will not work for what I'm using it for.
"Additionally, on ESP32/S2/C3/S3/C2, this function cannot be used to hold the state of a digital GPIO during Deep-sleep. Even if this function is enabled, the digital GPIO will be reset to its default state when the chip wakes up from Deep-sleep. If you want to hold the state of a digital GPIO during Deep-sleep, please call gpio_deep_sleep_hold_en."
However, based on what I'm observed, gpio_hold_en is all that is needed to keep the pin pulled up during sleep, and had no need to call gpio_deep_sleep_hold_en.
Hopefully someone can explain the difference in deep sleep between these two chips and why I am having to change my application to accommodate the ESP32-S3.
