Random String generation
amehta
Postby amehta » Sat Feb 17, 2018 11:30 am
I am trying to look for a method to generate RANDOM STRING in ESP32, but couldn't find it. Can somebody please point me in the right direction?
I have found the ability to generate RANDOM NUMBER using uint32_t esp_random(void); of esp_system.h but I am looking for a random alphanumeric string generation.
iot_guy
Re: Random String generation
Postby iot_guy » Sat Feb 17, 2018 3:02 pm
Use a random number as the ASCII code for each character in the string. E.g. (not tested)
// Generate random string in "str" of length "len" chars
static void get_random_string(char *str, unsigned int len)
    unsigned int i;
    // reseed the random number generator
    srand(time(NULL));
    for (i = 0; i < len; i++)
        // Add random printable ASCII char
        str[i] = (rand() % ('~' - ' ')) + ' ';
    str[i] = '\0';
static char string[21];
// Get random string of length 10
get_random_string(string, 10);
print("random string = %s\n", string);
Note: Be very careful with random variable generation if using them for cryptographic reasons (not a trivial subject)! The above method would not suffice for cryptographic purposes. srand is also not thread safe.
tele_player
Postby tele_player » Sat Feb 17, 2018 5:29 pm
Caution: the code listed above has a bug, it writes beyond the end of the array.
WiFive
Postby WiFive » Sat Feb 17, 2018 6:31 pm
Base64 encode?
Users browsing this forum: Amazon [Bot], ChatGPT-User, Google [Bot], PerplexityBot and 2 guests
