ESP32 - I2C Scanner using Arduino IDE (working)
jgustavoam
Contact:
Postby jgustavoam » Sat Feb 17, 2018 3:17 pm
Picture of circuit ( ESP32 DEVKIT) :
https://www.flickr.com/photos/jgustavoa ... 409004158/
I did my first test with I2C Interface using Arduino IDE. And it works !
I2C scanner based on code of Nick Gammon http://www.gammon.com.au/forum/?id=10896
Very simple ! The I2C clock frequency is almost 100 KHz (97.96 KHz). I can't change this.
NOTE > PCF8574 - max frequency = 100 KHz (does not work with 400 KHz).
PCF8574 Datasheet = https://www.nxp.com/docs/en/data-sheet/ ... F8574A.pdf
Circuit Diagram - SDA = GPIO_21 and SCL = GPIO_22 .
Very Important = You MUST use Pullup Resistors of 3K3 ohms.
Without then it does not work ! I still do not know, how to configure (Arduino IDE) pullup internal resistors. Change jumpers A0,A1 and A2 to modify address. Default PCF8574 address is 0x20 ( Decimal 32).
Picture of circuit diagram:
Decoding I2C Pulses with Logic Analyzer :
I2C Scanner (Arduino IDE 1.8.5) :
[code]
// ESP32 I2C Scanner
// Based on code of Nick Gammon  http://www.gammon.com.au/forum/?id=10896
// ESP32 DevKit - Arduino IDE 1.8.5
// Device tested PCF8574 - Use pullup resistors 3K3 ohms !
// PCF8574 Default Freq 100 KHz
#include <Wire.h>
void setup()
  Serial.begin (115200);
  Wire.begin (21, 22);   // sda= GPIO_21 /scl= GPIO_22
void Scanner ()
  Serial.println ();
  Serial.println ("I2C scanner. Scanning ...");
  byte count = 0;
  Wire.begin();
  for (byte i = 8; i < 120; i++)
    Wire.beginTransmission (i);          // Begin I2C transmission Address (i)
    if (Wire.endTransmission () == 0)  // Receive 0 = success (ACK response)
      Serial.print ("Found address: ");
      Serial.print (i, DEC);
      Serial.print (" (0x");
      Serial.print (i, HEX);     // PCF8574 7 bit address
      Serial.println (")");
      count++;
  Serial.print ("Found ");
  Serial.print (count, DEC);        // numbers of devices
  Serial.println (" device(s).");
void loop()
  Scanner ();
  delay (100);
[/code]
Console IDE (115200 Bps)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:812
load:0x40078000,len:0
load:0x40078000,len:11404
entry 0x40078a28
Found address: 32 (0x20)
Found 1 device(s).
Found 1 device(s).
Retired IBM Brasil
jgustavoam
Contact:
Re: ESP32 - I2C Scanner using Arduino IDE (working)
Postby jgustavoam » Sun Feb 09, 2020 1:13 pm
If you do not intend to use external pullup resistors for the I2C interface, you can configure internal pullups.
ESP32 Arduino driver/i2c.h
https://github.com/espressif/arduino-es ... iver/i2c.h
i2c_config_t Struct
gpio_pullup_t sda_pullup_en; /*!< Internal GPIO pull mode for I2C sda signal*/
gpio_pullup_t scl_pullup_en; /*!< Internal GPIO pull mode for I2C scl signal*/
* @brief Configure GPIO signal for I2C sck and sda
* @param i2c_num I2C port number
* @param sda_io_num GPIO number for I2C sda signal
* @param scl_io_num GPIO number for I2C scl signal
* @param sda_pullup_en Whether to enable the internal pullup for sda pin
* @param scl_pullup_en Whether to enable the internal pullup for scl pin
* @param mode I2C mode
* @return
* - ESP_OK Success
* - ESP_ERR_INVALID_ARG Parameter error
esp_err_t i2c_set_pin(i2c_port_t i2c_num, int sda_io_num, int scl_io_num,
gpio_pullup_t sda_pullup_en, gpio_pullup_t scl_pullup_en, i2c_mode_t mode);
Retired IBM Brasil
