Kconfig syntax error on set default
espmich
Postby espmich » Sat Dec 27, 2025 7:30 pm
I'm trying to use the set default construct in my Kconfig.projbuild file, but getting the error esp-idf kconfig error couldn't parse set default syntax error.
The set default construct is defined in the online Kconfig documentation:
set_default ::= "set default" + assignment [+ "if" + expression ]
https://docs.espressif.com/projects/esp ... lt-options
I've tried several things to troubleshoot the syntax error, and here is my ESP-IDF 5.5.1 command:
user@host:~/myproj$ idf.py menuconfig
Executing action: menuconfig
Running ninja in directory /home/user/myproj/build
Executing "ninja menuconfig"...
kconfiglib.core.KconfigError: /home/user/myproj/main/Kconfig.projbuild:53: error: couldn't parse 'set default APP_I2C_GPIO_SCL=21': syntax error
CMake Error at /home/user/myproj/esp-idf-551/tools/cmake/kconfig.cmake:237 (message):
  Failed to run kconfgen
FAILED: build.ninja
Diagnosis
It seems there are two version of Kconfig used by ESP-IDF, the versions v2 and v3. Maybe v3 added the set default construct, and maybe ESP-IDF 5.5.1 by default only uses v2?
Question
If the set default construct is only available in Kconfig v3 and later, then how can I force my ESP-IDF installation to use Kconfig v3 instead of v2?
Workaround
I only need the set default construct to build a configuration for several device models, is there another way to do this?
menu "Device Version"
    help
        Select the hardware revision of the device.
    comment "Find the hardware revision number on the back of the PCB."
    config APP_HW_VERSION_0_8_22
        bool "0.8.22"
        default n
        set default APP_I2C_GPIO_SDA=20
        set default APP_BUTTON_1_NUM_GPIO=9
        set default APP_BUTTON_2_NUM_GPIO=10
    config APP_HW_VERSION_0_8_21
        bool "0.8.21"
        default n
        set default APP_I2C_GPIO_SCL=12
        set default APP_I2C_GPIO_SDA=13
        set default APP_BUTTON_1_NUM_GPIO=19
        set default APP_BUTTON_2_NUM_GPIO=20
endmenu
nopnop2002
Contact:
Re: Kconfig syntax error on set default
Postby nopnop2002 » Sun Dec 28, 2025 7:49 am
menu "Application Configuration"
  choice
    prompt "Select the hardware revision of the device."
    default APP_HW_VERSION_0_8_22
    help
        bool "APP_HW_VERSION_0_8_22"
        bool "APP_HW_VERSION_0_8_21"
  endchoice
  config APP_I2C_GPIO_SCL
    int
    default 21 if APP_HW_VERSION_0_8_22
    default 12 if APP_HW_VERSION_0_8_21
endmenu
Users browsing this forum: Qwantbot and 5 guests
