S3 boot log - with fuse??
Posted: Sun Dec 28, 2025 2:53 pm
(S3 mini )
I'm trying to do a serial reflash for the first time and can't get GPIO0 to change the boot mode; could this be a fuse issue? and if so what would a boot log look like if it was a fuse issue?
I'm always getting exactly the same boot messages (below) with the boot type 0f 0x8, but I can see the pin labelled as GPIO0 on the PCB (which apparently goes to pin 4) seems to have a diode drop to ground if I measure it with a meter; so it's connected to *something*.
(I'm trying to recover after having programmed my 2nd attempt at Rust which just instantiated it's own usb-serial device but has ended up not enumerating at all any more on USB, hence why I'm trying to GPIO0 it)
Thanks,
Dave
Other suggestions?
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:2
load:0x3fce2810,len:0x15a0
load:0x403c8700,len:0x4
load:0x403c8704,len:0xd24
load:0x403cb700,len:0x2f04
entry 0x403c8928
I (30) boot: ESP-IDF v5.4.1-426-g3ad36321ea 2nd stage bootloader
I (30) boot: compile time Apr 24 2025 15:55:11
I (30) boot: Multicore bootloader
I (32) boot: chip revision: v0.1
I (34) boot: efuse block revision: v1.2
I (38) boot.esp32s3: Boot SPI Speed : 40MHz
I (42) boot.esp32s3: SPI Mode : DIO
I (46) boot.esp32s3: SPI Flash Size : 4MB
I (49) boot: Enabling RNG early entropy source...
I (54) boot: Partition Table:
I (56) boot: ## Label Usage Type ST Offset Length
I (63) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (69) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (76) boot: 2 factory factory app 00 00 00010000 003f0000
I (82) boot: End of partition table
I (86) esp_image: segment 0: paddr=00010020 vaddr=3c000020 size=0bfd4h ( 49108) map
I (105) esp_image: segment 1: paddr=0001bffc vaddr=3fc96148 size=027c4h ( 10180) load
I (108) esp_image: segment 2: paddr=0001e7c8 vaddr=40378000 size=01850h ( 6224) load
I (111) esp_image: segment 3: paddr=00020020 vaddr=42010020 size=4f8f4h (325876) map
I (196) esp_image: segment 4: paddr=0006f91c vaddr=40379850 size=0c8f4h ( 51444) load
I (222) boot: Loaded app from partition at offset 0x10000
I (222) boot: Disabling RNG early entropy source...
(S3 mini )
Thanks,
Dave
Other suggestions?
Build:Mar 27 2021
SPIWP:0xee
entry 0x403c8928
