Convert your USB Keyboard into a BLE Keyboard using ESP32-S3
Posted: Fri Jan 02, 2026 7:45 pm
For convenient use with a SmartTV I wanted to build a bluetooth keyboard. I had a wired keyboard laying around, so wanted to use it with ESP32-S3 to add BLE to it.
Ended up building a PlatformIO project for ESP32-S3, where it uses the USB-OTG as a host, to which we connect the USB Keyboard through a USB hub for power source. Then it becomes accessible as a BLE Keyboard that you can connect to from your phone, computer or a Smart TV.
The project also supports 3 separate slots, so you can quickly change between devices through a keyboard shortcut.
Link to the project if you want to try it out: https://github.com/KoStard/ESP32S3-USB-Keyboard-To-BLE
Note: The powering setup currently makes it not super portable, as you need either a power adapter or a power bank. Could be interesting to explore some battery power approaches.
