How to get the display module working?
Posted: Tue Jan 06, 2026 9:25 am
I have a Unihiker-K10 board that has ILI9341 display on it. I am at the moment not able to get the display work.
I have followed some online tutorials for this display and official IDF-Component but seems that it is not working properly. The configuration that this display has is as follows in the code
https://circuitlabs.net/lcd-oled-displa ... h-esp-idf/
Also the reset is connected to 3v3 via resistor and other side to capacitor to GND. There is no specific pin for Reset.
Anyone has an idea how to get this display to work?
static void display_init() {
spi_bus_config_t spi_bus = {
.sclk_io_num = LCD_SCLK,
.mosi_io_num = LCD_MOSI,
.miso_io_num = -1,
.quadwp_io_num = -1,
.quadhd_io_num = -1,
.max_transfer_sz = 240 * 80 * sizeof(uint16_t),
ESP_ERROR_CHECK(spi_bus_initialize(LCD_HOST, &spi_bus, SPI_DMA_CH_AUTO));
esp_lcd_panel_io_spi_config_t io_config = {
.dc_gpio_num = LCD_DC,
.cs_gpio_num = LCD_CS,
.pclk_hz = 40*1000*1000,
.lcd_cmd_bits = LCD_CMD_BITS,
.lcd_param_bits = LCD_PARAM_BITS,
.spi_mode = 0,
.trans_queue_depth = 10,
.on_color_trans_done = NULL,
.user_ctx = NULL,
esp_lcd_new_panel_io_spi((esp_lcd_spi_bus_handle_t)LCD_HOST, &io_config, &io_handle);
esp_lcd_panel_dev_config_t panel_config = {
.reset_gpio_num = -1,
.rgb_ele_order = LCD_RGB_ELEMENT_ORDER_BGR,
.bits_per_pixel = 16,
// Create LCD panel handle for ILI9341, with the SPI IO device handle
ESP_ERROR_CHECK(esp_lcd_new_panel_ili9341(io_handle, &panel_config, &panel_handle));
esp_lcd_panel_reset(panel_handle);
esp_lcd_panel_init(panel_handle);
esp_lcd_panel_disp_on_off(panel_handle, true);
