ESP32-WROOM-S3 WiFi Connection issues
Posted: Fri Jan 09, 2026 12:14 am
Hi -
I have projects with ESP32-WROOM-S3 and an ESP32-C3 Super Mini and neither are reliably connecting to my network. Like 1 out of 50 times they will connect. I have google fiber and I have 2 access points. I have both a 2.4GHz and a 5GHz network. The 2.5 and 5GHz networks have different SSIDs so I know I'm trying to connect to my 2.4GHz network. I have the security protocol set to WPA2. I am certain I am using the correct SSID and password. It works sometimes. I know my code is finding my network as I list it on the screen with its RSSI, Channel, and BSSID.
It "seems" to work better with one of the access points turned off, but even then, it is not very reliable. I have strong signal (25dBm) with my closest AP is on and 60dBm when its off. I've written code to try to force the higher signal strength ( WiFi.begin(ssid, password, ch, bssid, /*connect=*/true); ) . Nothing I'm doing is working.
What is odd is that this exact code "used" to work every time. I did switch to Google Fiber and it "may" be related to that, it's WiFi, or the multiple Access Points (I didn't used to have 2). I have always had 2.5GHz and 5GHz so I don't believe that is an issue.
I am now having the exact same issue with my ESP32-S3 and my ESP32-C3 where I didn't have these issues before. I've tried everything I can think of and that Co-Pilot can think of. Does anyone know of issues with Google Fiber WiFi or maybe their WPA2?
