How to do atomic operations like atomic_fetch_add on ESP32 in ESP-IDF?
Posted: Fri Jan 16, 2026 8:59 am
I’m using ESP32(xtensa) with ESP-IDF and I’d like to perform atomic operations such as atomic_fetch_add on shared variables (instead of always using mutexes or critical sections).
I checked the ESP-IDF Programming Guide and the Miscellaneous System APIs section, and I only found esp_cpu_compare_and_set() which does an atomic compare‑and‑set on a volatile uint32_t * and returns whether the value was updated.[ESP32 misc API]
From the ESP-IDF release notes I also see that additional atomic builtins like __atomic_OP_fetch_n and __sync_OP_and_fetch_n were implemented in newlib for ESP-IDF, but there is no clear example of how to use them in user code.[v4.3.3 changelog; v4.4 changelog]
My questions are:
- On ESP32, what is the recommended way in ESP-IDF to implement something equivalent to atomic_fetch_add on a shared counter?
- Should I build it myself using esp_cpu_compare_and_set() (CAS loop)?[ESP32 misc API]
- Or should I directly use the compiler/newlib builtins like __atomic_fetch_add / __sync_fetch_and_add that are mentioned in the changelog?[v4.3.3 changelog; v4.4 changelog]
- Are there any official examples or documentation from Espressif that show how to use these atomic builtins (or other ESP-IDF APIs) to implement operations like atomic_fetch_add, atomic_exchange, etc.?
- Do these atomic operations on ESP32 map to hardware support, or are they implemented via software (locks/critical sections) under the hood?
I’ve read the Programming Guide but couldn’t find a concrete API for atomic_fetch_add, so any guidance or example code would be very helpful.
Thanks!
My questions are:
Thanks!
