ESP32-C6 Super Mini
johnhb
ESP32-C6 Super Mini
Postby johnhb » Tue Jan 20, 2026 12:30 am
Has anyone used this new product from Espressif Systems? I purchased three units from AliExpress that are TZT ESP32-C6 dev modules.
Despite trying several different boards in Arduino I cannot upload a sketch. The USB type C cable I am using works perfectly on ESP32 D1 modules so I am sure it's not the connection.
I have read the troubleshooting.html and have tried the Boot button but still cannot upload a sketch.
Here is what I get as an error:
Sketch uses 957058 bytes (73%) of program storage space. Maximum is 1310720 bytes.
Global variables use 40220 bytes (12%) of dynamic memory, leaving 287460 bytes for local variables. Maximum is 327680 bytes.
esptool v5.1.0
Serial port COM3:
Connecting...
A serial exception error occurred: Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system is not functioning.', None, 31)
Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or drivers.
For troubleshooting steps visit: https://docs.espressif.com/projects/esp ... oting.html
Connected to ESP32-C6 on COM3:
Chip type: ESP32-C6FH4 (QFN32) (revision v0.2)
Features: Wi-Fi 6, BT 5 (LE), IEEE802.15.4, Single Core + LP Core, 160MHz
Crystal frequency: 40MHz
USB mode: USB-Serial/JTAG
MAC: 58:e6:c5:ff:fe:18:cb:5c
BASE MAC: 58:e6:c5:18:cb:5c
MAC_EXT: ff:fe
Uploading stub flasher...
Running stub flasher...
Stub flasher running.
Hard resetting via RTS pin...
Failed uploading: uploading error: exit status 1
Re: ESP32-C6 Super Mini
Postby Sprite » Tue Jan 20, 2026 2:17 am
Note that while the ESP32 chips on them are, these boards are not manufactured by Espressif. In which way did you try the boot button? The proper procedure is to press and hold boot, then momentarily press and release reset, then release boot, then try to upload. You may need to press reset again after uploading to get into the program you flashed.
johnhb
Postby johnhb » Tue Jan 20, 2026 3:34 am
Thanks Sprite. Yes I tried that method several times. Hold the Boot button, press/release Reset button and release Boot button. That method changes the USB Com port from 3 to 10. Also tried the method suggested by Espressif that is to hold the Boot button down until upload is completed. Neither of these methods worked.
Postby Sprite » Tue Jan 20, 2026 8:38 am
Can you try another computer, or another OS (e.g. Linux, a live boot stick or something) on the same computer? The reason that your ESP32-D1 works may be because it uses a different USB-serial method (external chip vs internal USB-serial-jtag) and your computer may react differently on that
johnhb
Postby johnhb » Tue Jan 20, 2026 9:56 am
Thanks Sprite. I only have one computer running Windows 11. If I cannot readily and easily upload sketches to the ESP32-C6 Super Mini then I will abandon their use. I don't want to spend extra time in trying to upload a sketch via a different operating system. I have ordered three WaveShare ESP32-C6-Mini dev boards from Core Electronics. It will be interesting to see if I have the same problem uploading a sketch or if these unit upload easily.
Users browsing this forum: PerplexityBot and 15 guests
