SPI Behaves Strange Under RTOS
saahinduran
Postby saahinduran » Sat Jan 24, 2026 9:30 am
Hello All,
I am pretty sure that I am coming with a strange one. I'll keep it as short as possible.
I wrote my own SPI driver in order to accelerate JTAG transfers of the CMSIS-DAP firmware.
However, what I see is that:
1) In a while(1) loop under app_main task, everything is fine. Transfers are superfast, data is correctly driven and sampled.
2) Under RTOS, I mean after creating a task and using the same codes there, SPI master and slave sometimes drive the line different from the value that I provide.
I am attaching the codes for SPI Full duplex communication and SPI Slave buffer enqueuing, and while(1) loop under app_main which behaves correctly, respectively.
Here is the list of what I tried:
1) I put the codes in critical section: NO HELP.
2) I moved the task to core1 while moving ALL other tasks to core0: NO HELP.
void SPI_SendReceive(uint8_t *sendBuff, uint8_t *readBuff, uint32_t len)
    portENTER_CRITICAL(
        &spi_spinlock
    uint32_t tempLen = len;
    if(tempLen < 32)
        tempLen = 4;
    else if(tempLen == 512)
        tempLen = 64;
    else
        tempLen = len / 8 + (len %8 ? 1 : 0);
    // 1. Wait for Idle
    while (SPI_HW->cmd.usr);
    // Reset the "Async FIFO" (AFIFO) pointers
    SPI_HW->dma_conf.buf_afifo_rst = 1;
    while (SPI_HW->dma_conf.buf_afifo_rst);
    SPI_HW->dma_conf.rx_afifo_rst = 1;
    while (SPI_HW->dma_conf.rx_afifo_rst);
    // 4. Fill Buffer (Using 32-bit Access Fix)
    //memcpy(&(SPI_HW->data_buf[0]), sendBuff, tempLen);
    // Use 32-bit access. memcpy is unsafe for APB registers.
    uint32_t byte_len = (len + 7) / 8;
    uint32_t words = (byte_len + 3) / 4;
    volatile uint32_t *fifo = (volatile uint32_t *)SPI_HW->data_buf;
    int i;
    for(int j = 0; j < 4; j++)
        for(i=0; i<words; i++) {
            uint32_t word = 0;
            if(i*4 < byte_len) word |= sendBuff[i*4];
            if(i*4+1 < byte_len) word |= (sendBuff[i*4+1] << 8);
            if(i*4+2 < byte_len) word |= (sendBuff[i*4+2] << 16);
            if(i*4+3 < byte_len) word |= (sendBuff[i*4+3] << 24);
            fifo[i] = word;
    memset(&fifo[i], 0, (16- words) * 4);
    // 2. Setup Bit Length (bits - 1)
    SPI_HW->ms_dlen.ms_data_bitlen = len - 1;
    __asm__ volatile("memw");
        // 5. Update Configuration (Vital for S3)
    SPI_HW->cmd.update = 1;
    while (SPI_HW->cmd.update);
    // 6. Execute
    SPI_HW->cmd.usr = 1;
    // 7. Read Buffer (Using 32-bit Access Fix)
    //memcpy(readBuff, &(SPI_HW->data_buf[0]), tempLen);
    // 8. Read Data (if needed)
   if (readBuff) {
	   for(int i=0; i<words; i++) {
		   uint32_t word = fifo[i];
		   if(i*4 < byte_len) readBuff[i*4] = word & 0xFF;
		   if(i*4+1 < byte_len) readBuff[i*4+1] = (word >> 8) & 0xFF;
		   if(i*4+2 < byte_len) readBuff[i*4+2] = (word >> 16) & 0xFF;
		   if(i*4+3 < byte_len) readBuff[i*4+3] = (word >> 24) & 0xFF;
   portEXIT_CRITICAL(
         &spi_spinlock
static portMUX_TYPE spi_spinlock = portMUX_INITIALIZER_UNLOCKED;
void SPI_SlaveQueue(uint8_t *sendBuff, uint32_t len)
    portENTER_CRITICAL(
        &spi_spinlock
    if(tempLen < 32)
        tempLen = 4;
        tempLen = 64;
    else
    while(SPI_SLAVE_HW->cmd.usr);
        memcpy(&(SPI_SLAVE_HW->data_buf[0]), sendBuff, tempLen);
    SPI_SLAVE_HW->slave.soft_reset = 1;
    while (SPI_SLAVE_HW->slave.soft_reset);
    SPI_SLAVE_HW->dma_conf.buf_afifo_rst = 1;
    while (SPI_SLAVE_HW->dma_conf.buf_afifo_rst);
    SPI_SLAVE_HW->dma_conf.rx_afifo_rst = 1;
    while (SPI_SLAVE_HW->dma_conf.rx_afifo_rst);
    SPI_SLAVE_HW->cmd.update = 1;
    while(SPI_SLAVE_HW->cmd.update);
    // 6. Execute
    SPI_SLAVE_HW->cmd.usr = 1;
    portEXIT_CRITICAL(
         &spi_spinlock
while (1)
		volatile uint32_t use_tms_proper = 0 , use_tdi_proper = 0;
        int64_t start = esp_timer_get_time();
        if(use_tms_proper)
        	SPI_Transmit_TMS(tms, 128);
        else
            SPI_SlaveQueue(tms, 128);
        if(use_tdi_proper)
        	SPI_Transmit_TDI_TDO (tdi, tdo, 128);
        else
        	SPI_SendReceive(tdi, tdo, 128);
        tms[0]++;
        tdi[0]++;
        tms[1]++;
        tdi[1]++;
        tms[2]++;
        tdi[2]++;
        tms[3]++;
        tdi[3]++;
        tms[4]++;
        tdi[4]++;
        tms[5]++;
        tdi[5]++;
        tms[6]++;
        tdi[6]++;
        tms[7]++;
        tdi[7]++;
        tms[8]++;
        tdi[8]++;
        tms[9]++;
        tdi[9]++;
        tms[10]++;
        tdi[10]++;
        tms[11]++;
        tdi[11]++;
        tms[12]++;
        tdi[12]++;
		//printf("write successful\n");
		sleep(0.02);
By the way, TMS is driven by SPI Slave, TDI is driven my master, and TDO is sampled by master. TRST corresponds to CS line between them.
PLEASE see the screenshot below. Transaction happens under a FreeRTOS task. You will see that at bit 17, there is a 1 which was not supposed to be there as the 3rd byte of TDI buffer is completely zero.
Below transaction happens under app_main task. As you see, line is driven correctly.
WHY do you think this strange behavior occurs?
Re: SPI Behaves Strange Under RTOS
Postby Sprite » Tue Jan 27, 2026 3:51 am
FWIW, in both cases you're running under RTOS, as app_main() is simply another RTOS task, just one which is implicitly created by ESP-IDF rather than one you created explicitly.
saahinduran
Postby saahinduran » Tue Jan 27, 2026 5:52 am
Hello, thanks for the reply.
Yes, I am aware that app_main is an rtos task that is whether statically allocated (in my case) or randomly assigned to a core.
What I mean by "Under RTOS", is that when I create a task which does network (TCP+WIFI) stuff which results in TCP and WIFI stack to operate on the other core.
I highly suspect that ERRATA [CACHE-126] Cache Hit Error During Cache Write-Backs causes my syndrome. I believe that critical section in one core does not prevent the other core to perform context switches resulting in usage of cache. In order to verify this, I will allocate all tasks to single core and keep my driver code in critical section+ perform cache operations to make sure that write back is complete.
I will let you know the results.
Şahin
saahinduran
Postby saahinduran » Tue Jan 27, 2026 5:10 pm
I tried to allocate everything to core0 and let core1 idle. I protected the driver code with critical section. NO RESULT. Module behaves strangely.
Even ESP-IDF framework SPI drivers will not work.
saahinduran
Postby saahinduran » Sun Feb 22, 2026 5:36 pm
I have found the solution.
The issues are caused by two reasons:
1) Signal integrity. When I try to scope the signals via an FPGA's internal logic analyzer, something went wrong which I don't understand. But after couple of weeks counsealing with AI, upon its suggestion, I simply inserted a series resistor to the lines that I drive. Now I can scope the lines and drive the correct data.
2) ESP32's SPI Master is not capable of driving data length % 8 == 1 (in bits). I made a workaround for this one as well.
Now it works like charm excep that I divide transactions for data length % 8 == 1 (in bits).
