OPC-UA working with WiFi but not with ETH
black.m
Postby black.m » Mon Jan 26, 2026 9:45 am
I am currently trying to get OPC UA (open62541) running on my ESP32-WROVER.
At the moment, everything works fine when using WiFi. However, as soon as I switch from WiFi to Ethernet, I can no longer reliably connect to the OPC UA server. Sometimes it works, but most of the time I only see that a client is trying to connect, while the connection itself never succeeds.
[2026-01-26 09:42:05.708 (UTC+0000)] info/userland     20 Variablen erfolgreich erstellt
[2026-01-26 09:42:05.715 (UTC+0000)] info/network       TCP network layer listening on opc.tcp://10.16.200.9:4840/
Time synchronization event received
[2026-01-26 10:42:10.901 (UTC+0100)] info/network       Connection 57 | New connection over TCP
[2026-01-26 10:42:10.927 (UTC+0100)] info/channel       Connection 57 | SecureChannel 1 | SecureChannel opened with SecurityPolicy http://opcfoundation.org/UA/SecurityPolicy#None and a revised lifetime of 300.00s
[2026-01-26 10:42:11.199 (UTC+0100)] info/channel       Connection 57 | SecureChannel 1 | CloseSecureChannel
[2026-01-26 10:42:11.212 (UTC+0100)] info/network       Connection 57 | Closed
[2026-01-26 10:42:11.234 (UTC+0100)] info/network       Connection 57 | New connection over TCP
[2026-01-26 10:42:11.259 (UTC+0100)] info/channel       Connection 57 | SecureChannel 2 | SecureChannel opened with SecurityPolicy http://opcfoundation.org/UA/SecurityPolicy#None and a revised lifetime of 600.00s
With WiFi I use:
UA_UInt16 waitMs = UA_Server_run_iterate(serverOPC, false);
When using Ethernet, I tried setting the parameter to true. In that case, the connection is established slightly more often, but it still fails in about 4 out of 5 attempts.
The funny thing is that sometimes it works perfectly with Ethernet, but as soon as I restart the ESP, it stops working again.
To me, this looks like a timing issue, but I honestly have no idea where to start debugging.
robin2906
Re: OPC-UA working with WiFi but not with ETH
Postby robin2906 » Tue Mar 10, 2026 1:27 pm
Hi @black.m ,
What version of open62541 are you using ? 1.5 ?
Best regards,
Users browsing this forum: Bing [Bot] and 2 guests
