Wifi stops working, wifi-task at 100%
timm_f
Postby timm_f » Mon Feb 02, 2026 10:45 am
our esp32-based device operate in station-mode connected to an access point.
We test the devices making approx. 1-3 HTTPS-requests to the device per second.
Some devices WIFI stopped responding after 1-4 days.
It can be seen that the task "wifi" on core 1 is at 100%. A power-cycle fixes the problem until it happens again.
The task "wifi" is from the esp-idf component.
I updated esp-idf from 4.4.4 to 4.4.8 as there is an entry in changelog: "fix(wifi): fix wifi station no response after m f null".
16 devices were running okay for 5 days then one device again showed this error.
It is a mass production device and customers did not report anything like that. Maybe they don't use Wifi often.
I wasn't able to reproduce it in a debug-build.
One problem is that Wifi comes as precompiled library without sourcecode. It would be helpful to have this sourcecode to diagnose this issue.
Does anyone know a way to further diagnose or remediate this? Or how to obtain Wifi-library sourcecode?
mikemoy
Re: Wifi stops working, wifi-task at 100%
Postby mikemoy » Thu Feb 19, 2026 2:50 pm
Sounds more like you need to make some changes for the WiFi in menuconfig. Larger buffers and what not.
Users browsing this forum: Applebot, Baidu [Spider] and 1 guest
